Pega Scenario Testing failed on blank text field
I am performing Pega scenario test with the case type. When I create a scenario test , wizard recording starts then I entered all the field value in it and saved the test case.
When I ran the scenario test 3-4 text field it remains blank and eventually test result is getting failed.
I am expecting solution on this.
Thank you.
***Edited by Moderator Marije to change Content Type from Discussion to Question; added capability tags***
