Coforge
Last activity: 7 Aug 2023 10:32 EDT
Pega startup fails post 7.x to 8.7.3 upgrade
Background
Upgraded from 7.1.9 to 8.7.3
moved from jboss to tomcat
updated oracle 12c to 19c before update
Below error in logs during startup & app fails to startup
ga.pegarules.pub.database.DatabaseException: Database-General Problem reading class definitions 17430 99999 Must be logged on to server
DatabaseException caused by prior exception: java.sql.SQLException: Must be logged on to server
| SQL Code: 17430 | SQL State: 99999
SQL: select pzPVStream from PEGA_RULES_NEW.pr4_base where pxObjClass = ?
SQL Inserts: <Rule-Obj-Class>
Background
Caused by SQL Problems.
Problem #1, SQLState 99999, Error code 17430: java.sql.SQLException: Must be logged on to server
2022-11-28 13:09:40,092 [StartUp-TaskExecutor] [ ] [ ] [ ] (ternal.dictionary.ClassMapImpl) INFO - ClassMapData is not preloaded
2022-11-28 13:09:40,092 [StartUp-TaskExecutor] [ ] [ ] [ ] (ary.ClassMapDatabasePageReader) INFO - ClassMap using multi-tenant environment: false
2022-11-28 13:09:40,093 [StartUp-TaskExecutor] [ ] [ ] [ ] (ary.ClassMapDatabasePageReader) INFO - Reading the class group definitions
2022-11-28 13:09:40,123 [StartUp-TaskExecutor] [ ] [ ] [ ] (ary.ClassMapDatabasePageReader) INFO - Read 155 class group definitions
2022-11-28 13:09:40,124 [StartUp-TaskExecutor] [ ] [ ] [ ] (ary.ClassMapDatabasePageReader) INFO - Reading the class definitions
2022-11-28 13:09:40,124 [StartUp-TaskExecutor] [ ] [ ] [ ] (ccess.DatabaseImpl.SystemPulse) INFO - Using a pulse offset of 60000 ms
2022-11-28 13:10:40,854 [StartUp-TaskExecutor] [ ] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Bytes input per interaction warning threshold: 50M
2022-11-28 13:10:40,854 [StartUp-TaskExecutor] [ ] [ ] [ ] (ternal.dictionary.ClassMapImpl) INFO - ClassMapData is not preloaded
2022-11-28 13:10:40,854 [StartUp-TaskExecutor] [ ] [ ] [ ] (ary.ClassMapDatabasePageReader) INFO - ClassMap using multi-tenant environment: false
2022-11-28 13:10:40,854 [StartUp-TaskExecutor] [ ] [ ] [ ] (ary.ClassMapDatabasePageReader) INFO - Reading the class group definitions
2022-11-28 13:10:40,885 [StartUp-TaskExecutor] [ ] [ ] [ ] (ary.ClassMapDatabasePageReader) INFO - Read 155 class group definitions
2022-11-28 13:10:40,885 [StartUp-TaskExecutor] [ ] [ ] [ ] (ary.ClassMapDatabasePageReader) INFO - Reading the class definitions
2022-11-28 13:11:46,452 [ rh0365v] [ ] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Bytes input per interaction warning threshold: 50M
2022-11-28 13:11:46,453 [ rh0365v] [ ] [ ] [ ] (ternal.dictionary.ClassMapImpl) INFO - ClassMapData is not preloaded
2022-11-28 13:11:46,453 [ rh0365v] [ ] [ ] [ ] (ary.ClassMapDatabasePageReader) INFO - ClassMap using multi-tenant environment: false
2022-11-28 13:11:46,453 [ rh0365v] [ ] [ ] [ ] (ary.ClassMapDatabasePageReader) INFO - Reading the class group definitions
2022-11-28 13:11:46,483 [ rh0365v] [ ] [ ] [ ] (ary.ClassMapDatabasePageReader) INFO - Read 155 class group definitions
2022-11-28 13:11:46,484 [ rh0365v] [ ] [ ] [ ] (ary.ClassMapDatabasePageReader) INFO - Reading the class definitions
2022-11-28 13:12:52,282 [StartUp-TaskExecutor] [ ] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Bytes input per interaction warning threshold: 50M
2022-11-28 13:12:52,282 [StartUp-TaskExecutor] [ ] [ ] [ ] (ternal.dictionary.ClassMapImpl) INFO - ClassMapData is not preloaded
2022-11-28 13:12:52,282 [ rh0365v] [ ] [ ] [ ] ( etier.impl.EngineStartup) ERROR - PegaRULES initialization failed. Server: unknown
com.pega.pegarules.pub.context.InitializationFailedError: PRNodeImpl init failed
at com.pega.pegarules.session.internal.mgmt.PREnvironment.getThreadAndInitialize(PREnvironment.java:442) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.PRSessionProviderImpl.getThreadAndInitialize(PRSessionProviderImpl.java:2169) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineStartup.initEngine(EngineStartup.java:726) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._initEngine_privact(EngineImpl.java:180) ~[prprivate-session.jar:?]
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.doStartup(EngineImpl.java:152) ~[prprivate-session.jar:?]
at com.pega.pegarules.web.servlet.WebAppLifeCycleListener._contextInitialized_privact(WebAppLifeCycleListener.java:216) ~[prwebj2ee.jar:?]
at com.pega.pegarules.web.servlet.AbstractLifeCycleListener._contextInitialized_privact(AbstractLifeCycleListener.java:145) ~[prwebj2ee.jar:?]
at com.pega.pegarules.web.servlet.AbstractLifeCycleListener.contextInitialized(AbstractLifeCycleListener.java:76) ~[prwebj2ee.jar:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:388) ~[prbootstrap-8.7.3-469.jar:8.7.3-469]
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:430) ~[prbootstrap-8.7.3-469.jar:8.7.3-469]
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:225) ~[prbootstrap-api-8.7.3-469.jar:8.7.3-469]
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:274) ~[prbootstrap-api-8.7.3-469.jar:8.7.3-469]
at com.pega.pegarules.internal.web.servlet.WebAppLifeCycleListenerBoot.contextInitialized(WebAppLifeCycleListenerBoot.java:92) ~[prbootstrap-api-8.7.3-469.jar:8.7.3-469]
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4768) ~[catalina.jar:9.0.65]
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5230) ~[catalina.jar:9.0.65]
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183) ~[catalina.jar:9.0.65]
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:726) ~[catalina.jar:9.0.65]
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:698) ~[catalina.jar:9.0.65]
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:696) ~[catalina.jar:9.0.65]
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:1024) ~[catalina.jar:9.0.65]
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1911) ~[catalina.jar:9.0.65]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) ~[?:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:264) ~[?:?]
at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75) ~[tomcat-util.jar:9.0.65]
at java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:118) ~[?:?]
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:825) ~[catalina.jar:9.0.65]
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:475) ~[catalina.jar:9.0.65]
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1618) ~[catalina.jar:9.0.65]
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:319) ~[catalina.jar:9.0.65]
at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:123) ~[catalina.jar:9.0.65]
at org.apache.catalina.util.LifecycleBase.setStateInternal(LifecycleBase.java:423) ~[catalina.jar:9.0.65]
at org.apache.catalina.util.LifecycleBase.setState(LifecycleBase.java:366) ~[catalina.jar:9.0.65]
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:946) ~[catalina.jar:9.0.65]
at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:835) ~[catalina.jar:9.0.65]
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1396) ~[catalina.jar:9.0.65]
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1386) ~[catalina.jar:9.0.65]
at java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:140) ~[?:?]
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:919) ~[catalina.jar:9.0.65]
at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:265) ~[catalina.jar:9.0.65]
at org.apache.catalina.core.StandardService.startInternal(StandardService.java:432) ~[catalina.jar:9.0.65]
at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:930) ~[catalina.jar:9.0.65]
***Edited by Moderator Marissa to change type from Product to Update***
