The Swedish Federation of Unemployment Insurance Funds
SE
Last activity: 14 Oct 2022 6:54 EDT
Field Value not displayed in Table filter pop up after selecting Optimize code
Field Value not displayed in Table column filter pop up after selecting "Optimize code" in table configuration on general tab in version Pega 8.5.3 but it works fine without selecting Optimize code.
And data (row values) in table display field values with "Optimize code".
Also Filetring value of column does not have option "Format" or "Value" after selecting "Optimize code".
***Edited by Moderator Marije to add BUG, Support Case Details; ***
Siddhant Suryakant Jivane -
Updated: 14 Oct 2022 6:54 EDT
Is this a personalized table? If so note that the localized value in filter popup is currently not supported with personalized tables. A workaround can be to create appropriate field values for the entries or use old grid (uncheck optimize code).
Check the below links;
1) https://community.pega.com/support/support-articles/localized-value-does-not-display-grid-filter
Also please note that in your version filter values will not get rendered localized in the grids. This has been resolved by updating the localization values in the pzFilterUiLabel control .
You can test the fix by updating to Patch 8.5.6 which was released April 2022
You can read about the fix in the 8.5.6 Patch Resolved Issues . Check for the description under ISSUE-674103 for 'Localization added for FilterUILabel'.
Can you confirm that you logged support incident INC-244648 for this?
Hi @SyedKausarH
With optimize code, there are fewer options available.
please refer to article, it says
When you optimize table code, some table configuration options are disabled. For example, if you use optimized tables, you cannot set a report definition as a data source, or use a custom category template. Because the availability of options also depends on other factors, such as the table context and other options that you select, see the Layout properties window to verify which options are available
https://docs-previous.pega.com/user-experience/85/optimizing-table-code?
SE
Thanks @kammv for your response but it seems a product bug because column values display field values (In Swedish) but filter of same column does not display field values (filter display in English).
Like in attached screen shot, Stage (Steg) column value is in Swedish (Samla Information) and in filter it displays in English.
Andy thought on this?
SE
I could not understand what is meant by personalized table. But I need to use optimized code to improve performance and allow user to save filtered views and not customization is done for table.
@MarijeSchillernYes Marije I have raised INC-244648 .
@SyedKausarH For the Personalize table parameter, did you select the Allow check box?
See documentation Enabling table personalization.
Please try to test the filter localization on the latest Pega Patch if you can.
I will let my colleague Artur help you further in the support incident.
SE
Yes @MarijeSchillern thats the requirement to allow to personalize and save veiws.
And thanks, will try to test on latest Pega patch then.
@SyedKausarH I can see that INC-244648 was closed with the understanding that you will update to the latest patch to resolve the issue.
