de Volksbank
de Volksbank
de Volksbank
Posted: May 3, 2021
Last activity: May 4, 2021
Last activity: 4 May 2021 3:37 EDT
How to select multiple rows in a table after applying filters on columns.
Hi Team,
We have requirement as below.
- List of items showed in a table with check box option for each item to select.
- User will apply some filters on columns.(To get sub set of items which they are looking for)
- User expecting one button Called Select All, once user click on the button then all the filtered rows(sub set of items) should be selected (check box should be checked)
Any thoughts on point 3? how we can achieve it.
@Bh@nupr@k@sh good morning.
Without knowing how the implementation is, I would say that the button SELECT ALL will have an action set to Refresh the section using a Data Transform that selects all the rows in the list. I would suggest to use pySelected property to store the checkbox value.
Hope this helps,
Iñigo.
