Upgrade - migrate bat file failed to run - Pega 7.1.9
Steps:
- Downloaded pega 719 package
- unzipped the file
- Updated migratesystem.properties as advise in upgrade document
- from command prompat went to the local direcotry where script folder is in unzipped filed from above
- Run the migrate.bat
Error:
The JAVA_HOME environment variable must be defined.
The system cannot find the batch label specified - Error
Can someone advise if this can be run from local machine? and if yes what action I should take to resolve the issue encountered.
