Regarding this error:x doesn't exist or is not a valid entry for this ruleset and its prerequisites
I created generic properties in "Apol-Data-Details" class. i want this properties to use in "Apol-FW-ApoloIns-Work"class. For this i created a property with single page mode and in page definition i gave "Apol-Data-Details" class.After this i tried to use this properties in my section which is in "Apol-FW-ApoloIns-Work:" .But i am getting above error.
@muralig35
First property, second page property and the section rule you need to have in a RSV that is accessible by each other.
Say if you have properties in a branch, then save as section in same branch.(due to ruleset validation and application validation)
Hope this helps!
If you are already doing that, then refer once
https://support.pega.com/discussion/x-doesnt-exist-or-not-valid-entry-ruleset-and-its-prerequisites
