The Mitre Corporation
Last activity: 4 Dec 2017 17:39 EST
Connector Activity Class doesn't exist
I have been trying to access an external MSSQL database utilizing these instructions: https://www.pegaxchange.com/2017/02/19/access-ms-sql-server-db-from-pega-7/ . I get an error every time I try to move past the Connector Activity Class. "The specified class must exist." Am I missing a step?
I have read over the "About generating connector rules": https://community.pega.com/sites/default/files/help_v73/procomhelpmain.htm
Is there a specific naming convention for the external database? The example doesn't seem to follow the convention (Data-Admin-DB-Table). The documents specify the Data and Work classes, but I can't get it to work.
For your application you should create your own class if you need to use it. If you just want to try out, why not use the mentioned developer exercise system so all the classes is already in built.
