Capgemini
Last activity: 3 Jan 2017 9:52 EST
prpcUtils.bat archives prweb.war doesn't exist.
when i excuting the prpcutil.bat i got following error
C:\newpega\scripts\utils>C:\newpega\scripts\utils\prpcUtils.bat export
Invoke our ant script, passing in the arguments as collected
Buildfile: C:\newpega\scripts\utils\prpcUtils.xml
-init:
[pega:propertyparser] Reading Properties from : C:\newpega\scripts\utils/prp
ls.properties
[pega:propertyparser] pega.jdbc.driver.jar=D:/PEGA717/lib/ojdbc6.jar
[pega:propertyparser] pega.jdbc.driver.class=oracle.jdbc.OracleDriver
[pega:propertyparser] pega.database.type=oracledate
[pega:propertyparser] pega.jdbc.url=jdbcsqlserver//serverName:1433;SelectMet
cursor
[pega:propertyparser] pega.jdbc.username=D5WM3C2S/PegaServer
[pega:propertyparser] pega.jdbc.password=******
[pega:propertyparser] pega.agents.enable=true
[pega:propertyparser] column.population.job.mode=COMMANDLINE_JOB
[pega:propertyparser] user.temp.dir=D:/AutoTemp
[pega:propertyparser] import.archive.path=D:/importfile.zip
[pega:propertyparser] import.mode=import
[pega:propertyparser] import.existing.instances=skip
[pega:propertyparser] import.nofailonerror=false
[pega:propertyparser] import.commit.count=100
[pega:propertyparser] import.compile.libraries=true
[pega:propertyparser] import.codeset.name=Customer
[pega:propertyparser] import.codeset.version=01-01-01
[pega:propertyparser] export.archive.full.path=D:/Exportfile/OperatorBulkUpl
zip
[pega:propertyparser] export.startVersion=01-01-01
[pega:propertyparser] export.endVersion=01-01-01
[pega:propertyparser] export.application.context=DevOps:01-01-01
[pega:propertyparser] export.preserve.locks=false
[pega:propertyparser] expose.classes.included=
[pega:propertyparser] expose.included.descendent=true
[pega:propertyparser] expose.classes.excluded=
[pega:propertyparser] expose.excluded.descendent=true
[pega:propertyparser] expose.declareIndex.accessgroup=
[pega:propertyparser] expose.startKey=
[pega:propertyparser] expose.endKey=
[pega:propertyparser] expose.startDate=
[pega:propertyparser] expose.endDate=
[pega:propertyparser] expose.reindex=true
[pega:propertyparser] expose.reindexType=nonpega
[pega:propertyparser] expose.commitRate=100
[pega:propertyparser] expose.numOfThreads=
[pega:propertyparser] resave.classes.included=true
[pega:propertyparser] resave.included.descendent=true
[pega:propertyparser] resave.classes.excluded=false
[pega:propertyparser] resave.excluded.descendent=true
[pega:propertyparser] resave.startKey=
[pega:propertyparser] resave.endKey=
[pega:propertyparser] resave.startDate=
[pega:propertyparser] resave.endDate=
[pega:propertyparser] runagent.agentruleset=Pega-RulesEngine
[pega:propertyparser] runagent.agentname=PropertyOptimization
[pega:propertyparser] scan.applicationName=PegaRULES
[pega:propertyparser] scan.applicationVersion=
[pega:propertyparser] scan.lib.external.jars=
[pega:propertyparser] scan.result.file=E:/Results.csv
[pega:propertyparser] scan.ruletypes.file=E:/RuleTypes.txt
[pega:propertyparser] manage.hotfix=
[pega:propertyparser] syntax.rules.excludeCore=false
[pega:propertyparser] syntax.rules.allVersions=true
[pega:hasenoughspace] Found 13294284KB of free space on 'D:/AutoTemp'
[mkdir] Created dir: D:\AutoTemp\PegaInstallTemp-29-December-2016-11.22.
oad
r_temp
[echo] Using D:/AutoTemp/PegaInstallTemp-29-December-2016-11.22.25 for
all scratch space...
BUILD FAILED
C:\newpega\scripts\utils\prpcUtils.xml:212: src 'C:\newpega\archives\prweb.w
doesn't exist.
Total time: 0 seconds
Exiting with Error
***Moderator Edit: Vidyaranjan| Updated Categories***
What is your app server and version ?
Also what is your PRPC version ?
