Cox Communications
Last activity: 8 Mar 2017 7:57 EST
prpcUtils.bat export - unable to export the rules
we are trying to export one ruleset with prpcUtils.bat export , but it is not exporting the rules under the ruleset although it has some when rules, here is the parameters we are using
export.archive.full.path=C:/pega/pegascripts/archives/OSCARFW6.zip
export.classes.included=CCI-FW-OSCARFW
export.included.descendent=true
export.classes.excluded=
export.excluded.descendent=true
export.startVersion=01-01-01
export.endVersion=01-01-01
export.ruleset.name=OSCARFWTest
export.preserve.locks=false
Any idea what is missing here?
Cox Communications
Issue is fixed after setting the classes.included value to "Rule-"
Hi Veeranjan,
Make sure you have OSCARFWTest is an existing ruleset instance present in your PRPC system.
And also provide the below details -
1. PRPC version?
2. Provide log files to inspect export command output?
P.S:- Also I hope you have taken a look at the below PDN article's export section.
https://docs-previous.pega.com/how-import-or-export-archive-command-line
Cox Communications
I did see that link, PRPC version is 7.1.9, here is the log
-init:
[pega:propertyparser] Reading Properties from : c:\pega\pegascripts\scripts\utils/prpcUtils.properties
[pega:propertyparser] JAVA_HOME=C:/Program Files/Java/jdk1.7.0_45/
[pega:propertyparser] pega.database.type=oracledate
[pega:propertyparser] pega.jdbc.url=****************************************************************
[pega:propertyparser] pega.jdbc.driver.jar=C:/Users/vbonthu/Downloads/ojdbc7.jar
[pega:propertyparser] pega.jdbc.driver.class=oracle.jdbc.OracleDriver
[pega:propertyparser] pega.jdbc.username=pega_admin
[pega:propertyparser] pega.jdbc.password=******
[pega:propertyparser] pega.user.username=
[pega:propertyparser] pega.user.password=
[pega:propertyparser] rules.schema.name=PEGA_RULES
[pega:propertyparser] data.schema.name=PEGA_DATA
[pega:propertyparser] pega.agents.enable=true
[pega:propertyparser] column.population.job.mode=COMMANDLINE_JOB
[pega:propertyparser] user.temp.dir=C:/pega_temp
[pega:propertyparser] import.archive.path=C:/importfile.zip
[pega:propertyparser] import.mode=import
[pega:propertyparser] import.existing.instances=skip
[pega:propertyparser] import.nofailonerror=false
[pega:propertyparser] import.commit.count=100
[pega:propertyparser] import.compile.libraries=true
[pega:propertyparser] import.codeset.name=Customer
-init:
[pega:propertyparser] import.codeset.version=06-01-01
[pega:propertyparser] [email protected]
[pega:propertyparser] indexing.password=install
[pega:propertyparser] indexing.indextype=Data
[pega:propertyparser] export.archive.full.path=C:/pega/pegascripts/archives/OSCARFWTestWithRulesetVNumber.zip
[pega:propertyparser] export.classes.included=CCI
[pega:propertyparser] export.included.descendent=true
[pega:propertyparser] export.classes.excluded=
[pega:propertyparser] export.excluded.descendent=true
[pega:propertyparser] export.startVersion=01-01-01
[pega:propertyparser] export.endVersion=01-01-01
[pega:propertyparser] export.keys.file=
[pega:propertyparser] export.ruleset.name=OSCARFWTest
[pega:propertyparser] export.preserve.locks=false
[pega:propertyparser] export.migration.xml=
[pega:propertyparser] export.migration.date=
[pega:propertyparser] expose.classes.included=
[pega:propertyparser] expose.included.descendent=true
[pega:propertyparser] expose.classes.excluded=
[pega:propertyparser] expose.excluded.descendent=true
[pega:propertyparser] expose.declareIndex.accessgroup=
[pega:propertyparser] expose.startKey=
[pega:propertyparser] expose.endKey=
[pega:propertyparser] expose.startDate=
[pega:propertyparser] expose.endDate=
[pega:propertyparser] expose.reindex=true
[pega:propertyparser] expose.reindexType=nonpega
[pega:propertyparser] expose.commitRate=100
[pega:propertyparser] expose.numOfThreads=
[pega:propertyparser] resave.classes.included=true
[pega:propertyparser] resave.included.descendent=true
[pega:propertyparser] resave.classes.excluded=false
[pega:propertyparser] resave.excluded.descendent=true
[pega:propertyparser] resave.startKey=
[pega:propertyparser] resave.endKey=
[pega:propertyparser] resave.startDate=
[pega:propertyparser] resave.endDate=
[pega:propertyparser] runagent.agentruleset=Pega-RulesEngine
[pega:propertyparser] runagent.agentname=PropertyOptimization
[pega:propertyparser] scan.applicationName=PegaRULES
[pega:propertyparser] scan.applicationVersion=
[pega:propertyparser] scan.lib.external.jars=
[pega:propertyparser] scan.result.file=E:/Results.csv
[pega:propertyparser] scan.ruletypes.file=E:/RuleTypes.txt
[pega:propertyparser] hotfix.operation=
[pega:propertyparser] hotfix.DLFilePath=
[pega:propertyparser] hotfix.CatalogPath=
[pega:propertyparser] hotfix.scan.downloadPath=
[pega:propertyparser] hotfix.bypass.schema=false
[pega:propertyparser] hotfix.force=false
[pega:propertyparser] syntax.rules.excludeCore=false
[pega:propertyparser] syntax.rules.allVersions=true
[pega:hasenoughspace] Found 300422904KB of free space on 'C:\Users\vbonthu\AppData\Local\Temp\'
[mkdir] Created dir: C:\Users\vbonthu\AppData\Local\Temp\PegaInstallTemp-09-March-2016-13.51.24\load
[mkdir] Created dir: C:\Users\vbonthu\AppData\Local\Temp\PegaInstallTemp-09-March-2016-13.51.24\pr_temp
[echo] Using C:\Users\vbonthu\AppData\Local\Temp\/PegaInstallTemp-09-March-2016-13.51.24 for install scratch space...
[unzip] Expanding: c:\pega\pegascripts\archives\pegadbinstall-classes.zip into C:\Users\vbonthu\AppData\Local\Temp\PegaInstallTemp-09-March-2016-13.51.24\load
[unzip] Expanding: c:\pega\pegascripts\archives\prweb.war into C:\Users\vbonthu\AppData\Local\Temp\PegaInstallTemp-09-March-2016-13.51.24\load
[copy] Copying 1 file to C:\Users\vbonthu\AppData\Local\Temp\PegaInstallTemp-09-March-2016-13.51.24\load\lib
[copy] Copying 1 file to C:\Users\vbonthu\AppData\Local\Temp\PegaInstallTemp-09-March-2016-13.51.24\load\WEB-INF\classes
Checking Configuration Files:
_findSystemName:
[echo] select max(s.pySystemName) from PEGA_DATA.pr_data_admin s inner join PEGA_DATA.pr_data_admin r on s.pySystemName = r.pySystemName where s.pxobjclass = 'Data-Admin-System' and r.pxObjClass = 'Data-Admin-Requestor'
Processing Configuration Files:
[propertyfile] Creating new property file: C:\Users\vbonthu\AppData\Local\Temp\PegaInstallTemp-09-March-2016-13.51.24\prbootstrap.properties
Configuration:
[echo] Database Type: oracledate
[echo] JDBC Driver JAR: C:/Users/vbonthu/Downloads/ojdbc7.jar
[echo] Bootstrap Config: C:\Users\vbonthu\AppData\Local\Temp\/PegaInstallTemp-09-March-2016-13.51.24/prbootstrap.properties
[echo] PegaRULES Config: C:\Users\vbonthu\AppData\Local\Temp\/PegaInstallTemp-09-March-2016-13.51.24/prconfig.xml
[echo] PegaRULES Logging Config: C:\Users\vbonthu\AppData\Local\Temp\/PegaInstallTemp-09-March-2016-13.51.24/prlogging.xml
-exportArchive:
[echo] about to Export Rules to : C:/pega/pegascripts/archives/OSCARFWTestWithRulesetVNumber.zip archive ...
[echo] arg line : -C CCI -v 01-01-01 -V 01-01-01 -n OSCARFWTest
[java] Mar 09, 2016 1:51:36 PM com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource
[java] 19830421: Loading bootstrap properties from file:///C:\Users\vbonthu\AppData\Local\Temp\/PegaInstallTemp-09-March-2016-13.51.24/prbootstrap.properties
[java] Mar 09, 2016 1:51:36 PM com.pega.pegarules.internal.bootstrap.SettingReaderJNDI
[java] 19830421: Could not find java:comp/env/prbootstrap/ in the local JNDI context, skipping prconfig setting lookup
[java] 19830421: Could not find prbootstrap in the local JNDI context, skipping prconfig setting lookup
[java] 19830421: Bootstrap datatables schema: PEGA_DATA
[java] Mar 09, 2016 1:51:38 PM com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource
[java] 19830421: Archive version [0]
[java] 19830421: Engine schema defined in allclasses: null
[java] Mar 09, 2016 1:51:38 PM com.pega.pegarules.internal.bootstrap.SettingReaderJNDI
[java] 19830421: Could not find java:comp/env/prconfig/ in the local JNDI context, skipping prconfig setting lookup
[java] 19830421: Could not find prconfig in the local JNDI context, skipping prconfig setting lookup
[java] 19830421: Engine classes schema: null
[java] 19830421: Assembled classes schema: null
[java] 19830421: prbootstrap.properties merged with prbootstrap entries in Data-Admin-System-Settings
[java] Mar 09, 2016 1:51:38 PM com.pega.pegarules.internal.bootstrap.PRMiniLoader
[java] 19830421: Will load phase 2 bootstrap from Pega-EngineCode:07-10-19
[java] Mar 09, 2016 1:51:38 PM com.pega.pegarules.internal.bootstrap.phase2.PRBootstrapImpl
[java] INFO: Using PRAppLoader implementation class: com.pega.pegarules.bootstrap.loader.PRAppLoader
[java] Mar 09, 2016 1:51:59 PM com.pega.pegarules.internal.bootstrap.phase2.PRBootstrapImpl
[java] 19830421: PegaRULES signed jar files will be extracted to: C:\Users\vbonthu\AppData\Local\Temp\/PegaInstallTemp-09-March-2016-13.51.24\extractedFiles
[java] WARNING: Cannot delete directory: extractedFiles
[java] Mar 09, 2016 1:52:01 PM com.pega.pegarules.internal.bootstrap.phase2.PRBootstrapImpl
[java] 19830421: PegaRULES classes will be loaded from the database
[java] Mar 09, 2016 1:52:01 PM com.pega.pegarules.internal.bootstrap.PRBootstrap
[java] 19830421:
[java] ============ PegaRULES Bootstrap Configuration ============
[java] Date: Wed Mar 09 13:52:01 EST 2016
[java] Java Version: Oracle Corporation 1.7.0_45
[java] Configuration: file:/C:/Users/vbonthu/AppData/Local/Temp//PegaInstallTemp-09-March-2016-13.51.24/prbootstrap.properties
[java] Pega-EngineCode: 07-10-19
[java] ASM Version: 554097615
[java] Database: Oracle Oracle Database 12c Enterprise Edition Release Proprietary information hidden.0 - 64bit Production
[java] With the Partitioning, Automatic Storage Management, OLAP, Advanced Analytics
[java] and Real Application Testing options
[java] Driver: Oracle JDBC driver Proprietary information hidden.0
[java] Active CodeSets: pega-enginecode:07-10-19 at (latest patch)
[java] customer:06-01-01 at (latest patch)
[java]
[java] =============== End Bootstrap Configuration ===============
[java]
[java] Current "user.dir" (default directory) is: C:\Users\vbonthu\AppData\Local\Temp\PegaInstallTemp-09-March-2016-13.51.24\load
[java] Located PegaRULES logging configuration: file:/C:/Users/vbonthu/AppData/Local/Temp/PegaInstallTemp-09-March-2016-13.51.24/load/WEB-INF/classes/prlogging.xml
[java] Found spec for PegaRULES (V5.x) configuration using System property: C:\Users\vbonthu\AppData\Local\Temp\/PegaInstallTemp-09-March-2016-13.51.24/prconfig.xml
[java] Located PegaRULES (V5.x) configuration: file:/C:/Users/vbonthu/AppData/Local/Temp/PegaInstallTemp-09-March-2016-13.51.24/prconfig.xml
[java] 2016-03-09 13:52:02,665 [ main] [ ] [ ] ( basic.config.SettingsImpl) WARN - *=================================================================*
[java] 2016-03-09 13:52:02,671 [ main] [ ] [ ] ( basic.config.SettingsImpl) WARN - prconfig.xml missing key for initialization/settingsource
[java] 2016-03-09 13:52:02,671 [ main] [ ] [ ] ( basic.config.SettingsImpl) WARN - This is likely due to using a copy of prconfig.xml from a previous install.
[java] 2016-03-09 13:52:02,671 [ main] [ ] [ ] ( basic.config.SettingsImpl) WARN - >> assuming "initialization/settingsource=file"; Note that
[java] 2016-03-09 13:52:02,671 [ main] [ ] [ ] ( basic.config.SettingsImpl) WARN - this excludes use of entries in Data-Admin-System-Settings as prconfig settings
[java] 2016-03-09 13:52:02,671 [ main] [ ] [ ] ( basic.config.SettingsImpl) WARN - *=================================================================*
[java] Mar 09, 2016 1:52:02 PM com.pega.pegarules.internal.bootstrap.SettingReaderJNDI
[java] 2016-03-09 13:52:02,977 [ main] [ ] [ ] (able.DefaultVirtualTableConfig) INFO - Using Hybrid Virtual Rules Table implementation
[java] 2016-03-09 13:52:02,977 [ main] [ ] [ ] (able.DefaultVirtualTableConfig) INFO - VTable dispatches rules for 7 Aspects: 'Collection, Validate, When, Model, Alias, Input, Action'.
[java] 2016-03-09 13:52:02,977 [ main] [ ] [ ] (able.DefaultVirtualTableConfig) INFO - ABA[AC] dispatches rules for 1 Aspect: 'Stream'.
[java] 2016-03-09 13:52:02,979 [ main] [ ] [ ] ( priv.context.JNDIEnvironment) INFO - Enterprise-tier default Engine bean name is EngineBMT
[java] 2016-03-09 13:52:02,984 [ main] [ ] [ ] (r.context.EtierEnvironmentImpl) WARN - Enterprise tier has no local JNDI context
[java] reason: Need to specify class name in environment or system property, or as an applet parameter, or in an application resource file: java.naming.factory.initial
[java] 2016-03-09 13:52:03,196 [ main] [ ] [ ] (ion.internal.PRGenProviderImpl) INFO - invokeDynamic instrumentation for inlining is enabled
[java] 2016-03-09 13:52:03,196 [ main] [ ] [ ] (ion.internal.PRGenProviderImpl) INFO - Assembly Version: 554097615
[java] 2016-03-09 13:52:03,487 [ main] [ ] [ ] ( internal.util.ExportImpl) WARN - Exported Archives are JAR files. The exported file will be C:/pega/pegascripts/archives/OSCARFWTestWithRulesetVNumber.jar
[java] 2016-03-09 13:52:03,521 [ main] [ ] [ ] ( internal.mgmt.EngineImpl) INFO - PegaRULES Embedded Edition 7.10 (ML9)
[java] 2016-03-09 13:52:03,521 [ main] [ ] [ ] ( internal.mgmt.EngineImpl) INFO - coreAssemblyCached_719_730: 2015-08-26 19.54 EDT
[java] 2016-03-09 13:52:03,521 [ main] [ ] [ ] ( internal.mgmt.EngineImpl) INFO - Now starting the PegaRULES Embedded Environment...
[java] 2016-03-09 13:52:03,643 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Base database information:
[java] 2016-03-09 13:52:03,643 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Database name: pegadata
[java] 2016-03-09 13:52:03,643 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Defined by: JDBC URL
[java] 2016-03-09 13:52:03,643 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - JDBC URL: jdbc:oracle:thin:@dukeordv95.corp.cox.com:1521:DOSCAR
[java] 2016-03-09 13:52:03,643 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Minimum connection count: 0
[java] 2016-03-09 13:52:03,643 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Maximum connection count: unlimited
[java] 2016-03-09 13:52:03,643 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Failover database: none
[java] 2016-03-09 13:52:03,643 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Default Schema: PEGA_DATA
[java] 2016-03-09 13:52:03,644 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Base database information:
[java] 2016-03-09 13:52:03,644 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Database name: pegarules
[java] 2016-03-09 13:52:03,645 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Defined by: JDBC URL
[java] 2016-03-09 13:52:03,645 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - JDBC URL: jdbc:oracle:thin:@dukeordv95.corp.cox.com:1521:DOSCAR
[java] 2016-03-09 13:52:03,645 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Minimum connection count: 0
[java] 2016-03-09 13:52:03,645 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Maximum connection count: unlimited
[java] 2016-03-09 13:52:03,645 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Failover database: none
[java] 2016-03-09 13:52:03,645 [ main] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Default Schema: PEGA_RULES
[java] 2016-03-09 13:52:04,325 [ main] [ ] [ ] ( external.timers.CpuTimer) INFO - CPU timers set to TOTALSONLY. Use prconfig setting 'initialization/CpuTimerLevel' with one of [FULL, TOTALSONLY, NONE] to modify.
[java] 2016-03-09 13:52:04,328 [ main] [ ] [ ] (.timers.EnvironmentDiagnostics) INFO - Using Java 1.5 Thread.getAllStackTraces() for thread dumps
[java] Using sun.misc.Perf high-resolution timer for elapsed timings
[java] Using Java 5 Management beans for thread CPU timings.
[java] Using Java 5 Management beans for process CPU timings: 9126058500
[java] 2016-03-09 13:52:04,539 [ main] [ ] [ ] (.access.PageDatabaseMapperImpl) INFO - DeflateStreams is turned ON.
[java] 2016-03-09 13:52:04,591 [ main] [ ] [ ] (pboard.StorageStreamCommonImpl) INFO - engineCodeVersion: 07-10-19
[java] Unable to locate KeyringImpl keyring after trying:
[java] <properties>
[java] vbonthu-pegarules.keyring
[java] CATL0W104L1LLV1-pegarules.keyring
[java] pegarules.keyring
[java] 2016-03-09 13:52:05,842 [ main] [ ] [ ] ( internal.archive.ParUtilsImpl) INFO - Setting archive staging directory: C:\Users\vbonthu\AppData\Local\Temp\PegaInstallTemp-09-March-2016-13.51.24\pr_temp\RuleMgmt
[java] 2016-03-09 13:52:05,843 [ main] [ ] [ ] ( etier.impl.EngineStartup) INFO - JVM Information:
[java] 2016-03-09 13:52:05,843 [ main] [ ] [ ] ( etier.impl.EngineStartup) INFO - Vendor: Oracle Corporation, JVM version: 1.7.0_45
[java] 2016-03-09 13:52:05,843 [ main] [ ] [ ] ( etier.impl.EngineStartup) INFO - VM Name: Java HotSpot(TM) 64-Bit Server VM(build 1.7.0_45-b18)
[java] 2016-03-09 13:52:05,843 [ main] [ ] [ ] ( etier.impl.EngineStartup) INFO - Host OS Information:
[java] 2016-03-09 13:52:05,843 [ main] [ ] [ ] ( etier.impl.EngineStartup) INFO - OS: Windows 7, version: 6.1
[java] 2016-03-09 13:52:05,843 [ main] [ ] [ ] ( etier.impl.EngineStartup) INFO - Architecture: amd64
[java] 2016-03-09 13:52:05,843 [ main] [ ] [ ] ( etier.impl.EngineStartup) INFO - PegaRULES Enterprise Tier 7.10 (ML9)
[java] 2016-03-09 13:52:05,843 [ main] [ ] [ ] ( etier.impl.EngineStartup) INFO - coreAssemblyCached_719_730: 2015-08-26 19.54 EDT
[java] 2016-03-09 13:52:05,843 [ main] [ ] [ ] ( etier.impl.EngineStartup) INFO - Deployed in both web and enterprise tier
[java] 2016-03-09 13:52:05,843 [ main] [ ] [ ] ( etier.impl.EngineStartup) INFO - Servlet container: null
[java] 2016-03-09 13:52:05,843 [ main] [ ] [ ] ( etier.impl.EngineStartup) INFO - Web server: null
[java] 2016-03-09 13:52:05,843 [ main] [ ] [ ] ( etier.impl.EngineStartup) INFO - Web server environment: null
[java] 2016-03-09 13:52:05,843 [ main] [ ] [ ] ( etier.impl.EngineStartup) INFO - Web-tier default Engine bean name: EngineBMT
[java] 2016-03-09 13:52:05,843 [ main] [ ] [ ] ( etier.impl.EngineStartup) INFO - Enterprise server environment: Unknown
[java] 2016-03-09 13:52:05,843 [ main] [ ] [ ] ( etier.impl.EngineStartup) INFO - Enterprise-tier default Engine bean name: EngineBMT
[java] 2016-03-09 13:52:05,843 [ main] [ ] [ ] ( etier.impl.EngineStartup) INFO - Web to Enterprise tier delegate type: null
[java] 2016-03-09 13:52:05,843 [ main] [ ] [ ] ( etier.impl.EngineStartup) INFO - Now starting the PegaRULES Engine...
[java] 2016-03-09 13:52:05,993 [ main] [ ] [ ] ( internal.mgmt.PRNodeImpl) INFO - Using codeset version and timestamp map: {pega-enginecode=07-10-19@2016-01-12 13:51:00.0, customer=06-01-01@2016-01-19 13:23:00.0}
[java] 2016-03-09 13:52:06,485 [ CATL0W104L1LLV1] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Generated source : file://runtime:/PRGenJava/
[java] 2016-03-09 13:52:06,485 [ CATL0W104L1LLV1] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Generated classes: file://runtime:/PRGenClasses/
[java] 2016-03-09 13:52:06,507 [ CATL0W104L1LLV1] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Web-tier real root path: null
[java] 2016-03-09 13:52:06,507 [ CATL0W104L1LLV1] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Web-tier temporary path: null
[java] 2016-03-09 13:52:06,507 [ CATL0W104L1LLV1] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - PegaRULES real root path: C:\Users\vbonthu\AppData\Local\Temp\pr_bogus_root_directory
[java] 2016-03-09 13:52:06,507 [ CATL0W104L1LLV1] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - PegaRULES effective root path: file://default:/
[java] 2016-03-09 13:52:06,507 [ CATL0W104L1LLV1] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - PegaRULES effective temp path: C:\Users\vbonthu\AppData\Local\Temp\PegaInstallTemp-09-March-2016-13.51.24\pr_temp
[java] 2016-03-09 13:52:06,507 [ CATL0W104L1LLV1] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Using genSourcePath: file://runtime:/PRGenJava/
[java] 2016-03-09 13:52:06,507 [ CATL0W104L1LLV1] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Using genClassPath (database): pegajdbc://1803296480:1/
[java] 2016-03-09 13:52:06,507 [ CATL0W104L1LLV1] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Using genClassPath (files): file://runtime:/PRGenClasses/
[java] 2016-03-09 13:52:06,507 [ CATL0W104L1LLV1] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Using external classes in: <not using external classes>
[java] 2016-03-09 13:52:06,507 [ CATL0W104L1LLV1] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Using external jars in: <not using external jars>
[java] 2016-03-09 13:52:06,671 [ CATL0W104L1LLV1] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Servlet classes: (none)
[java] 2016-03-09 13:52:06,671 [ CATL0W104L1LLV1] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - JSP classes: (none)
[java] 2016-03-09 13:52:06,671 [ CATL0W104L1LLV1] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - EJB classes: (none)
[java] 2016-03-09 13:52:06,671 [ CATL0W104L1LLV1] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - JMS classes: (none)
[java] 2016-03-09 13:52:07,030 [ CATL0W104L1LLV1] [ ] [ ] (rnal.access.CacheContainerImpl) INFO - Using the Dynamic Cache Probation Policy - cache after 2 accesses AND with a blob increment of 102400.
[java] 2016-03-09 13:52:07,268 [ CATL0W104L1LLV1] [ ] [ ] (pcentric.RACacheAppCentricImpl) INFO - Prune threshold is 10000
[java] 2016-03-09 13:52:07,268 [ CATL0W104L1LLV1] [ ] [ ] (pcentric.RACacheAppCentricImpl) INFO - mFUAReusableEnabled = true, mConstructorReuseEnabled = false, mFUAReusableEnabledStream = true
[java] 2016-03-09 13:52:07,344 [ CATL0W104L1LLV1] [ ] [ ] (pcentric.RACacheAppCentricImpl) INFO - Using RACacheAppCentricImpl for assembly cache implementations
[java] 2016-03-09 13:52:07,344 [ CATL0W104L1LLV1] [ ] [ ] (pcentric.RACacheAppCentricImpl) INFO - Assembly avoidance will use branch ruleset optimization
[java] 2016-03-09 13:52:07,344 [ CATL0W104L1LLV1] [ ] [ ] (nal.cache.AssemblyCacheWrapper) INFO - Assembly Cache Wrapper: configuredCacheType = AC
[java] 2016-03-09 13:52:07,459 [ CATL0W104L1LLV1] [ ] [ ] ( internal.mgmt.PRNodeImpl) INFO - MBean registered via PRNodeImpl: 8cccd53fce2acdf6fc56cfdcf2d1c961
[java] Located App Server independent MBean security configuration: pegajdbc://1803296480:0/prresources.jar!//prmbeans.properties
[java] 2016-03-09 13:52:07,482 [ CATL0W104L1LLV1] [ ] [ ] ( priv.management.MBeanSecurity) INFO - The following MBean security configuration has been applied:
[java] 2016-03-09 13:52:07,482 [ CATL0W104L1LLV1] [ ] [ ] ( priv.management.MBeanSecurity) INFO - deny.RequestorManagement.Clipboard=true
[java] 2016-03-09 13:52:07,482 [ CATL0W104L1LLV1] [ ] [ ] ( priv.management.MBeanSecurity) INFO - deny.RequestorManagement.RequestorDetails=true
[java] 2016-03-09 13:52:07,482 [ CATL0W104L1LLV1] [ ] [ ] ( priv.management.MBeanSecurity) INFO - deny.DatabaseManagement.DatabaseConnectionDetails=true
[java] 2016-03-09 13:52:08,053 [ CATL0W104L1LLV1] [ ] [ ] (riv.management.MBeanManagement) INFO - MBean Management (Web) initialized for DefaultDomain
[java] 2016-03-09 13:52:08,119 [ CATL0W104L1LLV1] [ ] [ ] ( internal.mgmt.PRRequestorImpl) INFO - RecordWorkInProgress is not enabled
[java] 2016-03-09 13:52:08,553 [ CATL0W104L1LLV1] [ ] [ ] (orization.SessionAuthorization) INFO - RSL Update Behavior: Eager
[java] 2016-03-09 13:52:08,838 [ CATL0W104L1LLV1] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Bytes input per interaction warning threshold: 50M
[java] 2016-03-09 13:52:08,848 [ CATL0W104L1LLV1] [ ] [ ] (ternal.dictionary.ClassMapImpl) INFO - ClassMap using multi-tenant environment: false
[java] 2016-03-09 13:52:08,848 [ CATL0W104L1LLV1] [ ] [ ] (ternal.dictionary.ClassMapImpl) INFO - Reading the class group definitions
[java] 2016-03-09 13:52:08,933 [ CATL0W104L1LLV1] [ ] [ ] (ternal.dictionary.ClassMapImpl) INFO - Read 20 class group definitions
[java] 2016-03-09 13:52:08,933 [ CATL0W104L1LLV1] [ ] [ ] (ternal.dictionary.ClassMapImpl) INFO - Reading the class definitions
[java] 2016-03-09 13:52:20,070 [ CATL0W104L1LLV1] [ ] [ ] (ternal.dictionary.ClassMapImpl) INFO - Read 4262 class definitions
[java] 2016-03-09 13:52:21,221 [ CATL0W104L1LLV1] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Database product: Oracle
[java] 2016-03-09 13:52:21,222 [ CATL0W104L1LLV1] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Database version: Oracle Database 12c Enterprise Edition Release Proprietary information hidden.0 - 64bit Production
[java] 2016-03-09 13:52:21,222 [ CATL0W104L1LLV1] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Driver: Oracle JDBC driver
[java] 2016-03-09 13:52:21,222 [ CATL0W104L1LLV1] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Driver version: Proprietary information hidden.0
[java] 2016-03-09 13:52:21,222 [ CATL0W104L1LLV1] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Version of JDBC supported by driver: 4.1
[java] PRPC default rounding mode set to HALF_EVEN
[java] 2016-03-09 13:52:29,701 [ CATL0W104L1LLV1] [ ] [ ] (pboard.StorageStreamCommonImpl) INFO - Storage stream version is 6
[java] 2016-03-09 13:52:32,086 [ LOAD_INSTANCEFILTER] [ STANDARD] [ ] ( external.async.IStartupTask) INFO - load instance filter ..starting
[java] 2016-03-09 13:52:32,086 [ LOAD_INSTANCEFILTER] [ STANDARD] [ ] (al.access.InstanceExistsFilter) INFO - Scanning instance ids
[java] 2016-03-09 13:52:32,090 [AD_DECLARATIVECOMMON] [ STANDARD] [ ] ( external.async.IStartupTask) INFO - load getDeclarativeCommon ..starting
[java] 2016-03-09 13:52:32,091 [AD_DECLARATIVECOMMON] [ STANDARD] [ ] ( external.async.IStartupTask) INFO - load getDeclarativeCommon ..done
[java] 2016-03-09 13:52:32,092 [EPAGEDEFINITIONCACHE] [ STANDARD] [ ] ( external.async.IStartupTask) INFO - load Declarative Page Definition Cache ..starting
[java] 2016-03-09 13:52:41,357 [EPAGEDEFINITIONCACHE] [ STANDARD] [ ] ( external.async.IStartupTask) INFO - load Declarative Page Definition Cache ..done
[java] 2016-03-09 13:52:52,232 [ LOAD_INSTANCEFILTER] [ STANDARD] [ ] (al.access.InstanceExistsFilter) INFO - Added 97692 entries to the instance exists filter in 20.145000 seconds with a false positive rate of 0.001
[java] 2016-03-09 13:52:52,232 [ LOAD_INSTANCEFILTER] [ STANDARD] [ ] ( external.async.IStartupTask) INFO - load instance filter ..done
[java] 2016-03-09 13:52:52,545 [ CATL0W104L1LLV1] [ STANDARD] [ ] ( internal.mgmt.PRNodeImpl) INFO - Created new node: "CATL0W104L1LLV1 prpc 2016-03-09 18:52:07.457 GMT", [8cccd53fce2acdf6fc56cfdcf2d1c961]
[java] 2016-03-09 13:52:52,585 [ CATL0W104L1LLV1] [ STANDARD] [ ] ( internal.mgmt.PRNodeImpl) INFO - Node Identification: "CATL0W104L1LLV1 prpc 2016-03-09 18:52:07.457 GMT"; Node Id: 8cccd53fce2acdf6fc56cfdcf2d1c961
[java] 2016-03-09 13:52:52,607 [ CATL0W104L1LLV1] [ STANDARD] [ ] ( internal.mgmt.PRNodeImpl) INFO - Starts joining cluster
[java] 2016-03-09 13:52:52,607 [ CATL0W104L1LLV1] [ STANDARD] [ ] ( internal.mgmt.PRNodeImpl) INFO - Ends joining cluster
[java] 2016-03-09 13:52:52,607 [ CATL0W104L1LLV1] [ STANDARD] [ ] ( internal.mgmt.PRNodeImpl) INFO - Clustering technology: none
[java] 2016-03-09 13:52:53,961 [ CATL0W104L1LLV1] [ STANDARD] [ ] ( internal.mgmt.PRNodeImpl) INFO - Checking Cluster consistency
[java] 2016-03-09 13:52:53,980 [ CATL0W104L1LLV1] [ STANDARD] [ ] (cluster.internal.PRClusterImpl) ERROR - Clustering has been disabled on this node by setting 'identification/cluster/protocol' to 'none', however the protocol currently being used by the cluster is 'hazelcast'. This inconsistency will cause functionality that uses the cluster to fail on this node and can lead to data consistency problems and potential data loss. This node should be shutdown and restarted with clustering enabled.
[java] 2016-03-09 13:52:54,017 [ CATL0W104L1LLV1] [ STANDARD] [ ] ( internal.mgmt.PRNodeImpl) INFO - PegaRULES extract marker file not found; resetting local caches
[java] 2016-03-09 13:52:54,031 [ CATL0W104L1LLV1] [ STANDARD] [ ] ( internal.mgmt.PRNodeImpl) INFO - Preparing Rule-Utility-Library definitions for use...
[java] 2016-03-09 14:03:11,619 [LOAD_PEGACONCLUSIONS] [ STANDARD] [ ] ( external.async.IStartupTask) INFO - load pegaConclusions ..starting
[java] 2016-03-09 14:03:11,621 [ALDECLARATIVECLASSES] [ STANDARD] [ ] ( external.async.IStartupTask) INFO - load global declarative classes ..starting
[java] 2016-03-09 14:03:11,621 [ALDECLARATIVECLASSES] [ STANDARD] [ ] (bi.DeclarativeCacheManagerImpl) INFO - Starting global declarative cache pre-load...
[java] 2016-03-09 14:03:25,759 [LOAD_PEGACONCLUSIONS] [ STANDARD] [ ] (dictionary.ConclusionCacheImpl) INFO - Starting conclusion pre-load...
[java] 2016-03-09 14:03:30,828 [ CATL0W104L1LLV1] [ STANDARD] [ ] (c.DependentRuleSetListPoolImpl) INFO - Loaded 1681 ruleset dependencies
[java] 2016-03-09 14:03:30,836 [l LOAD_ASSEMBLYCACHE] [ STANDARD] [ ] ( external.async.IStartupTask) INFO - load reloadCache ..starting
[java] 2016-03-09 14:03:30,837 [l LOAD_ASSEMBLYCACHE] [ STANDARD] [ ] (pcentric.RACacheAppCentricImpl) INFO - Start AppCentric reloadCache processing for node 8cccd53fce2acdf6fc56cfdcf2d1c961. Maximum age in hours for Usage data is 96. Maximum rows to load is 14400
[java] 2016-03-09 14:03:30,897 [ CATL0W104L1LLV1] [ STANDARD] [ ] (ternal.vtable.VirtualTableImpl) INFO - Virtual Table Preload Starting...
[java] 2016-03-09 14:03:31,274 [l LOAD_ASSEMBLYCACHE] [ STANDARD] [ ] (pcentric.RACacheAppCentricImpl) INFO - End of reload processing, loaded 0 rows, elapsed time is 438 milliseconds.
[java] 2016-03-09 14:03:31,274 [l LOAD_ASSEMBLYCACHE] [ STANDARD] [ ] (pcentric.RACacheAppCentricImpl) INFO - reload added 0 assembledClasses 0 shortcuts.
[java] 2016-03-09 14:03:31,274 [l LOAD_ASSEMBLYCACHE] [ STANDARD] [ ] ( external.async.IStartupTask) INFO - load reloadCache ..done
[java] 2016-03-09 14:03:39,168 [LOAD_PEGACONCLUSIONS] [ STANDARD] [ ] (dictionary.ConclusionCacheImpl) INFO - Pre-Loaded 23963 conclusions
[java] 2016-03-09 14:03:39,168 [LOAD_PEGACONCLUSIONS] [ STANDARD] [ ] ( external.async.IStartupTask) INFO - load pegaConclusions ..done
[java] 2016-03-09 14:03:41,910 [ CATL0W104L1LLV1] [ STANDARD] [ ] (ternal.vtable.VirtualTableImpl) INFO - ...Finished. Preloaded 10.2MB for 42553 rules in 11012 ms
[java] 2016-03-09 14:03:41,910 [ CATL0W104L1LLV1] [ STANDARD] [ ] ( internal.mgmt.PREnvironment) INFO - Skipping Services initialization.
[java] 2016-03-09 14:03:41,910 [ CATL0W104L1LLV1] [ STANDARD] [ ] ( external.async.IStartupTask) INFO - Awaiting for StartupTasks (parallel cache loading to finish)...
[java] 2016-03-09 14:03:56,878 [ALDECLARATIVECLASSES] [ STANDARD] [ ] (bi.DeclarativeCacheManagerImpl) INFO - Loaded 3905 global declarative cache instances
[java] 2016-03-09 14:03:56,878 [ALDECLARATIVECLASSES] [ STANDARD] [ ] ( external.async.IStartupTask) INFO - load global declarative classes ..done
[java] 2016-03-09 14:03:56,879 [ CATL0W104L1LLV1] [ STANDARD] [ ] ( external.async.IStartupTask) INFO - All registered 'StartupTasks' (parallel cache loading) have finished.
[java] 2016-03-09 14:03:57,064 [ CATL0W104L1LLV1] [ STANDARD] [ ] (al.async.AsyncServicesExecutor) INFO - PegaRULES Async service executor (thread pool) initialized in web-tier.
[java] 2016-03-09 14:03:57,082 [ CATL0W104L1LLV1] [ STANDARD] [ ] (nal.async.AsyncServicesManager) INFO - AsyncServicesManager initialized for node.
[java] 2016-03-09 14:03:58,322 [ CATL0W104L1LLV1] [ STANDARD] [ ] (pcentric.RACacheAppCentricImpl) WARN - Assembly pulse-based features disabled.
[java] 2016-03-09 14:03:58,760 [ CATL0W104L1LLV1] [ STANDARD] [ ] ( etier.impl.EngineStartup) INFO - Product type: Standard
[java] 2016-03-09 14:03:58,787 [ CATL0W104L1LLV1] [ STANDARD] [ ] ( etier.impl.EngineStartup) INFO - Agent is disabled, immediately set node's run state to running!!!
[java] 2016-03-09 14:03:58,813 [ CATL0W104L1LLV1] [ STANDARD] [ ] ( etier.impl.EngineStartup) INFO - PegaRULES engine successfully started. TimeZone: America/New_York AESPerfStatMode: PUSH Server: CATL0W104L1LLV1 System: prpc Description: CATL0W104L1LLV1 prpc 2016-03-09 18:52:07.457 GMT URL: [unable to determine]
[java] 2016-03-09 14:03:58,814 [ CATL0W104L1LLV1] [ STANDARD] [ ] ( internal.mgmt.EngineImpl) INFO - Embedded Environment initialization is complete.
[java] 2016-03-09 14:03:58,902 [ CATL0W104L1LLV1] [ STANDARD] [ ] (ternal.archive.PegaArchiveImpl) INFO - Creating Schema Archive: C:\Users\vbonthu\AppData\Local\Temp\PegaInstallTemp-09-March-2016-13.51.24\pr_temp\RuleMgmt\external\OSCARFWTestWithRulesetVNumber\schema\OSCARFWTestWithRulesetVNumber_schema.jar
[java] 2016-03-09 14:03:58,968 [ CATL0W104L1LLV1] [ STANDARD] [ ] ( internal.util.ExportImpl) INFO - Initializing default execution context.
[java] 2016-03-09 14:04:00,496 [ CATL0W104L1LLV1] [ STANDARD] [ ] ( internal.util.MoveLog) INFO - Operation Status: Exporting specification
[java] 2016-03-09 14:04:00,497 [ CATL0W104L1LLV1] [ STANDARD] [ ] ( internal.util.MoveLog) INFO - Operation Status: Export Complete
[java] 2016-03-09 14:04:00,969 [ CATL0W104L1LLV1] [ STANDARD] [ ] ( internal.util.MoveLog) INFO - Operation Status: Constructing export file -- please wait...
[java] 2016-03-09 14:04:00,975 [ CATL0W104L1LLV1] [ STANDARD] [ ] ( internal.util.MoveLog) INFO - Operation Status: Constructing export file -- please wait....
[java] 2016-03-09 14:04:00,976 [ CATL0W104L1LLV1] [ STANDARD] [ ] ( internal.util.MoveLog) INFO - Operation Status: Constructing export file -- please wait.....
[java] 2016-03-09 14:04:00,977 [ CATL0W104L1LLV1] [ STANDARD] [ ] ( internal.util.MoveLog) INFO - Operation Status: Constructing export file -- please wait......
[java] 2016-03-09 14:04:02,271 [ CATL0W104L1LLV1] [ STANDARD] [ ] ( internal.util.ExportImpl) INFO - Export complete.
-cleanup:
[echo] Cleaning up temp directory...
[delete] Deleting directory C:\Users\vbonthu\AppData\Local\Temp\PegaInstallTemp-09-March-2016-13.51.24
export:
[echo] PegaRULES Process Commander Export Archive complete.
BUILD SUCCESSFUL
Total time: 12 minutes 57 seconds
Exiting with NO Error
Hi Veeranjan,
From the logs, everything looks clean. If you are sure that output zip file doesn't contain any rulesets. I would request you to raise an SR.
Let us the latest update.
PEG
please grant below mentioned privileges to pega_admin user and run the scenario.
ANALYZE ANY
https://docs-previous.pega.com/pega-718-installation-guide-weblogic-oracle
Incase if it doesn't work please grant all the privileges mentioned in the deployment guide in Database setup section.
Cox Communications
General Electric
I am trying to export a product rule using prpcutils. I got the error
[java] SEVERE: Problem during method invocation (main)
[java] java.lang.OutOfMemoryError: Java heap space
BUILD FAILED /apps/NPICOEDatamig/SOFTWARE/prpcServiceUtils/scripts/utils/prpcUtils.xml:843: Java returned: 1
Below is the values provided
export.archive.full.path=/apps/NPICOEDatamig/SOFTWARE/TestExportPath/test.jar
export.archive.productkey=RULE-ADMIN-PRODUCT PQMDEMOJARFILE3 01-08-99 #20170204T150415.994 GMT
included.descendent : true (include descendants)
export.classes.included=Rule-
export.endVersion=
export.keys.file=
Can anyone help me on this
Thanks in advance
Shruthi
