Coforge
Coforge
Coforge
Posted: Apr 25, 2022
Last activity: Jun 28, 2022
Last activity: 28 Jun 2022 4:25 EDT
PrpcUtils script fails for export job
We have configure latest PrcUtils and Jenkins for export job but it is failing with below exception.
Show More
[mkdir] Created dir: /opt/prpcServiceUtils/prpcServiceUtils84/prpcServiceUtils/TempLogs/PegaInstallTemp-20-April-2022-15.42.18
[pega:hasenoughspace] Found 205786088KB of free space on '/opt/prpcServiceUtils/prpcServiceUtils84/prpcServiceUtils/TempLogs'
[echo] *** JVM Arguments -Xmx1280m -Dlog4j.configurationFile=file:///%2Fopt%2FprpcServiceUtils%2FprpcServiceUtils84%2FprpcServiceUtils%2Fscripts%2Flib%2Flog4j2.xml -Dlogfile.timestamp=Apr-20-2022-15-42-18 ***
-processInstances:
[echo] Performing export on multiple instance(s)
[pega:echoargline] arg line : -action export -propFileDir /opt/prpcServiceUtils/prpcServiceUtils84/prpcServiceUtils/scripts/utils/generated -poolSize ${prpcserviceutils.pool.size} -requestTimeOut ${prpcserviceutils.request.timeout} -tempDir /opt/prpcServiceUtils/prpcServiceUtils84/prpcServiceUtils/TempLogs/PegaInstallTemp-20-April-2022-15.42.18 -artifactsDir logs -processFailStrategy FAIL_PROCESS_ON_SINGLE_SYSTEM_FAILURE
[echo] Reading connection information from
BUILD FAILED
/opt/prpcServiceUtils/prpcServiceUtils84/prpcServiceUtils/scripts/utils/prpcServiceUtilsWrapper.xml:179: java.lang.IllegalArgumentException: Invalid File Path
at com.pega.pegarules.serviceclient.Validate.notZeroLength(Validate.java:36)
at com.pega.pegarules.util.anttasks.FileUtils.validateFile(FileUtils.java:39)
at com.pega.pegarules.util.anttasks.MultiSystemPropertyFileReader.validate(MultiSystemPropertyFileReader.java:126)
at com.pega.pegarules.util.anttasks.MultiSystemPropertyFileReader.<init>(MultiSystemPropertyFileReader.java:74)
at com.pega.pegarules.util.anttasks.PropertyFileGenerator.getReader(PropertyFileGenerator.java:251)
at com.pega.pegarules.util.anttasks.PropertyFileGenerator.execute(PropertyFileGenerator.java:208)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:292)
at sun.reflect.GeneratedMethodAccessor4.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:99)
at org.apache.tools.ant.Task.perform(Task.java:350)
at java.util.Vector.forEach(Vector.java:1277)
at org.apache.tools.ant.taskdefs.Sequential.execute(Sequential.java:67)
at net.sf.antcontrib.logic.IfTask.execute(IfTask.java:197)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at org.apache.tools.ant.TaskAdapter.execute(TaskAdapter.java:155)
at org.apache.tools.ant.Target.execute(Target.java:449)
at org.apache.tools.ant.Target.performTasks(Target.java:470)
at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1391)
at org.apache.tools.ant.Project.executeTarget(Project.java:1364)
at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
at org.apache.tools.ant.Project.executeTargets(Project.java:1254)
at org.apache.tools.ant.Main.runBuild(Main.java:830)
at org.apache.tools.ant.Main.startAnt(Main.java:223)
at org.apache.tools.ant.launch.Launcher.run(Launcher.java:284)
at org.apache.tools.ant.launch.Launcher.main(Launcher.java:101)
Show Less
