Upgrade Script Failing
Pega upgrade from 7.1.9 to 8.5( on Premise to On Premise )
App server –WebLogic Proprietary information hidden
DB Server – Oracle server Proprietary information hidden
We are struck with below error. Please guide. Ideally this has to work OOTB and need not be run manually correct ?
Please find the attached complete log
[java] Nov 01, 2021 11:28:21 AM com.pega.pegarules.internal.bootstrap.PRBootstrap
[java] SEVERE: Problem during method invocation (main)
[java] com.pega.pegarules.pub.database.NonexistentTableException: Database-NonexistentTable SWERULESMSO.pr4_rule_service_rest PegaRULES
[java] From: (unknown)
[java] at com.pega.pegarules.data.internal.store.TableInformationMapImpl.figureOutSchema(TableInformationMapImpl.java:774)
[java] at com.pega.pegarules.data.internal.store.TableInformationMapImpl.lookupRdbTableInfo(TableInformationMapImpl.java:444)
@Ratna What is the value set for "bypass.pega.schema" in setupDatabase.properties file? If it is set to true, can you set it to "false" and retry ?
