Job pyNodeCleaner failing
On one of our Production systems, the job pyNodeCleaner fails to run on all the web nodes. Results in a SQL error.
Error message: Job Scheduler [pyNodeCleaner] activity [pzNodeCleaner] execution marked as failed with message [There was a problem getting a list: code: 1795 SQLState: 42000 Message: ORA-01795: maximum number of expressions in a list is 1000<CR>]. Exception message [-].*
Having checked this table, pr_data_op_session there are 2.9m records in here dating back to 2021, with an avg of 400k in each created month.
The SQL being generated is below, shortened since it's very big.
Caused by: Error : 1795, Position : 73, Sql = DELETE FROM BASE.pr_data_op_session "PC0" WHERE ( "PC0"."PZREQUESTORID" IN (:1 , :2 , :3 , :4 , :5 , :6 , :7 , :8 , :9 , :10 , :11 , :12 , :13 , :14 , :15 , :16 , :17 , :18 , :19 , :20 , :21 , :22 , :23 , :24 , :25 , :26 , :27 , :28 , :29 , :30 , :31 , :32 , :33 , :34 , :35 , :36 , :37 , :38 , :39 , :40 , :41 , :42 , :43 , :44 , :45 , :46 , :47 , :48 , :49 , :50 , :51 , :52 , :53 , :54 , :55 , :56 , :57 , :58 , :59 , :60 , :61 , :62 , :63 , :64 , :65 , :66 , :67 , :68 , :69 , :70 , :71 , :72 , :73 , :74 , :75 , :76 , :77 , :78 , :79 , :80 , :81 , :82 , :83 , :84 , :85 , :86 , :87 , :88Any idea what causes this and how do we rectify?
Craig
***Edited by Moderator Marije to add possible BUG id***
