Charter
Last activity: 18 Mar 2024 10:12 EDT
Job Scheduler Failure due to Database Exception
I am running into a job scheduler failure, this has been happening for months.
The job scheduler is pyPegaArchivalVacuumFreeze, I am not sure if it failing because the DB table is empty or not.
The error is that it is a Database Exception (see stack trace below):
com.pega.platform.executor.jobscheduler.scheduler.JobExecutionException: Job Scheduler [pyPegaArchivalVacuumFreeze] activity [pzPegaArchivalVacuumFreeze]
execution marked as failed with message [Database Exception]
I have searched for documentation on this but there is very little on this particular OOTB job scheduler.
When I search in Pega for the java code to see where it is failing in that I cannot find the code.
Can someone please point me in the right direction for fixing this error
@BraydenH16937092
It's more likely your database is not PostgreSQL, which this is intended for. There is a bug because the SQL Connect rule states package as "ALL" instead of "postgres".
The SQL under Save shows "vacuum freeze {Class:Data-ArchivalMetadata}" which is specific to PostgreSQL and no other DB.
If your DB is not PostgreSQL, then disable this job.
Cheers
Craig
