Job scheduler named pyPersistNodeState failure
I am using pega platform v8.7.4 and noticed the following error during server startup -
[BSCHEDULER_THREAD_11] [ STANDARD] [ ] [ ] ( JobSchedulerExecution) ERROR B58K8GE0EMMO3W290H5DNE0YQGEQPORBHA - Exception in executing Job[pyPersistNodeState]
com.pega.platform.executor.jobscheduler.scheduler.JobExecutionException: Job Scheduler [pyPersistNodeState] activity [pzPersistNodeState] execution marked as failed with message [There is no configuration (no Data-Admin-DB-Name instance) for database Unable to obtain DataSource object]. Exception message [-].
at com.pega.platform.executor.jobscheduler.internal.JobSchedulerProcessor.identifyUserMarkedFailure(JobSchedulerProcessor.java:155) ~[pega-executor.jar:?]
at com.pega.platform.executor.jobscheduler.internal.JobSchedulerProcessor.execute(JobSchedulerProcessor.java:111) ~[pega-executor.jar:?]
at com.pega.platform.executor.jobscheduler.internal.JobSchedulerProcessor.lambda$execute$0(JobSchedulerProcessor.java:92) ~[pega-executor.jar:?]
at com.pega.platform.executor.internal.LogContextDecorator.runInDecoratedScope(LogContextDecorator.java:38) ~[pega-executor.jar:?]
at com.pega.platform.executor.jobscheduler.internal.JobSchedulerProcessor.execute(JobSchedulerProcessor.java:90) ~[pega-executor.jar:?]
at com.pega.platform.executor.jobscheduler.scheduler.internal.JobRunTimeImpl.execute(JobRunTimeImpl.java:104) ~[executor.jar:?]
at com.pega.platform.executor.jobscheduler.scheduler.internal.JobRunTimeDecorator.execute(JobRunTimeDecorator.java:57) ~[executor.jar:?]
at com.pega.platform.executor.jobscheduler.scheduler.internal.JobExecutionTemplate.executeJob(JobExecutionTemplate.java:56) ~[executor.jar:?]
at com.pega.platform.executor.jobscheduler.scheduler.internal.JobExecutionTemplate.run(JobExecutionTemplate.java:46) ~[executor.jar:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:1.8.0_302]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:1.8.0_302]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) ~[?:1.8.0_302]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) ~[?:1.8.0_302]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) ~[?:1.8.0_302]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) ~[?:1.8.0_302]
at java.lang.Thread.run(Thread.java:748) ~[?:1.8.0_302]
Any suggestins to fix this issue?
