Create case from job scheduler
I have an activity that has been written that will create a new case when it is run. I have found that if I run the activity manually (through Actions->Run button/menu) the case is created properly as expected. However, I would like to call the activity from a Job Scheduler rule. When I try to run the activity from the job scheduler, the case is not created and no errors are present in the log. Any ideas? Are there internal properties perhaps that get set/referenced when running via Dev Studio that are not set when running via a timed Job Scheduler?
Thanks in advance!
