Adqura
Last activity: 18 May 2021 5:19 EDT
Adaptive Model across 2 applications
Hi there,
Can we use ADM model to learn across 2 systems and give propensity based on the customer responses across systems where the offers are shared in 2 systems?
Consider I have 2 separate servers but sharing some of the offers across. Can I feed the outcomes in both systems and use propensity calculated across 2 systems?
Anand
Hi Anand,
Is this a question about scaling - e.g. have multiple systems that run the same application but are just different nodes? Or are you talking about two different (CDH) applications here?
If the latter - responses are responses to a certain offer that was given in a certain context, so it doesn't make sense to send the same response to different apps even if the offers are the same thing (the context at decision time will likely be different for both). But sharing data between those "brains" may be an option - especially interaction history is often something that is a good candidate to share between different apps.
Feel free to elaborate on your use case so we may be able to give a bit more guidance.
Cheers
Otto
