CDH - Unable to Finalize File output template
We have actions with flow tab having a simple flow where in a generic treatment properties we write to File ( in delivery options). In the File output template ( RULE-OBJ-TEMPLATE PEGAMKT-WORK-OFFER-xxxx-xxx) the repository, file path and finalize options everything was mentioned currently. However after latest deploy of code ( which is to do mostly only with engagement policies change) the Finalization is not happening when primary scheduler runs and/or even manually trying to finalize the template.
observations:
- The Primary scheduler run is stuck in forever Running state and showing result as blank
- We can see "etimated staged records" count correctly in the Fileoutputtemplate, but it is not just able to finalize in to a CSV
Any suggestion or ideas are welcome
