Rulesware LLC
MX
Last activity: 26 Feb 2021 10:06 EST
Run simulation test fails when created form CDH portal with a revision management
When on CDH Portal with Revision Manger access group operator, I created a simulation as indicated in the documentation and another by Audience Simulation at NBA Designer. Both simulations are created but fail when running them:
https://community.pega.com/knowledgebase/articles/decision-management/84/simulation-testing
Is there any special configuration needed for the operator when using Revision Management application overlays?
Notice that, if I run a simulation test from the main application there is no issue
@kamag
The simulation is working fine now in the application overlay.
Seems it was related to using a property calculated using a declare expression in the engagement policies, we replace that property for a when rule when we do the computation procedurally instead of declaratively. That fixed our other issue and seems also fixed this.
