Delete Campaigns
How can I delete campaigns?
***Edited by Moderator: Pooja Gadige to add product details tag***
Campaigns potentially have two separate instances defined for them in the class PegaMKT-Work. One starts with P-, which is the campaign information entered by the user, while the second starts with PR-, which holds the information for a run that is initiated. I've had luck just manually deleting both of these instances using Obj-Delete in a temp activity without any observable regressions. Not sure if this is the correct method, but it has worked for me.
Please review the documentation here for work object archive / purge : https://community.pega.com/sites/default/files/help_v718/procomhelpmain.htm#tools/purgearchive/aboutpurgearchivewizard.htm
I would highly discourage you from directly deleting instance like suggested in the above thread, given the dependencies in the index and other tables.
