Maximus
Last activity: 13 Oct 2020 12:07 EDT
Deploy step throws Socket timeout error in deployment manager
Hi Team,
We are currently deploying the changes to higher environment using Deployment manager(4.6) pipeline and Pega version 8.3.1. Recently, we are noticing the Deploy step which pushes the code to Test environment getting failed for first time. In logs, we see the below error.
ERROR Deploy task failed. Reason: Error creating Restoration pointCaught unhandled exception: java.lang.RuntimeException: java.net.SocketTimeoutException: Read timed out
Kindly help us with the resolution. While we trace it, we see pzexecuterestconnector activity step 5 fails with socket timeout error. But we could not see the reason for socket timeout error.
Deepa
