implement SearchWorkItem Gadget functionality in portal (Pega 8.4.1)
Im using pega 8.4.1 and I have try to Add SearchWorkItem Gadget functionality to portal in a upgrade project .
But i couldn't succeed. I have followed step as below
*) Created a new section and pasted the copied HTML in the HTML tab.
*) Referred that section in our portal section.
Are there any other way to implement this scenario?
***Edited by Moderator: Pallavi to change content type from Discussion to Question***
@AnuradhaW @JuliusM6
Live UI on the 8.4 Case Manager portal in UI Kit suggests the Section to embed in your Portal to provide the hook into Search is pySearchFieldWorkResponsive . If you are trying to wire in a different search gadget used from an earlier version of Pega then it may not work as the underlying Search architecture is continually evolving. I recommend transitioning to the latest implementation.
If you are looking to leverage a previous rule because you have customized it, I came across the following article yesterday while fielding a similar enquiry. Although the article lands under the Client Lifecycle Management product, all the extension points I checked in it are available from Platform.
https://community.pega.com/knowledgebase/articles/pega-client-lifecycle-management-financial-services/case-searches
You will likely be able to retrofit your existing customizations into this extension design available from the Platform.
