Offline Mobile App Synchronization error (Pega 8.4)
I tried to make an offline enabled mobile app in version 8.4 Even the most simple casetype with one text property gives a Synchronazation Error after logon.
I'm working with a PegaLabs Cloud system and offline disabled apps work correctly.
To figure this out I want to enable : synchronizationErrorTypeFilteringMode If posible, how can this be set with a PegaLabs system.
PEGA0066 alert: Mobile App Data-Sync Failure
<env name = “alerts/mobile/PRPCClientStore/synchronizationErrorTypeFilteringMode" value="NONE" />
The setting accepts one of the following values:
- NONE – No issues are logged by the system. This is the default setting.
- ALL_BUT_NETWORK_FAILURES – The system logs all failures reported by the device, except for the ones that relate to network connectivity.
- ALL_FAILURES – The system logs all failures reported by the device.
Stop and restart the server after you change the setting.
kind regards, Marius
