Facing Issue with BIX extracts
We have BIX extracts created for both Work class and History of Work class with checking "Use last updated time as start" checkbox so that extract will be incremental daily with no other filter. And a Job scheduler is created which will run BIX extracts daily at 12 AM. We are facing issue of missing afew instances in Work class extract but present in History extract for the same day. To be precise a work object created in the evening and afew rows are created in History but when the BIX extract is pulled for that day on the both the Work and History of Work class respectively sometime the instance is present only in History Extract and missing in Work extract, but receiving the missing instance in the next day extract of Work class. This is only for afew instances, please can someone let me know if am missing anything.
