CBA
REST connector that was created before version 8.2 of Pega Platform
I have tried to configure dynamically the resource path by using a data page similar to the approach that could be implemented for v7.3 (PFA snapshot), but it is not working in 8.3, and help content is not helpful really.
Please let me the know-how to change or workaround,PFA.
Updated: 14 Jun 2021 7:38 EDT
If we do not upgrade to New endpoint configuration, then in the Resource path, we can mention the DataPage.
Please find the below screenshot for more details.
You are using the new endpoint URL configuration, I don't think we can use the Data Page there. Instead, if you want to have a dynamic URL then you can use the Application setting.
CBA
Can you elaborate the fix, I am facing issue per your suggestion, PFA
Instead of using Data Page, is there a possibility to use the Application setting by creating a new application setting.
CBA
Referred this link, but facing same issue https://collaborate.pega.com/question/how-set-dynamic-url-pega-82-connect-rest-rule
In the Clipboard, did you check if the value is getting populated correctly?
CBA
None of the values are set in the clipboard
I mean do you have the value of the URL getting populated correctly.
