How to generate a specific sql statement where one filter is required only if a second filter exists
I've got a strange sql statement I need to build and I'm having trouble getting it done in Pega.
Suppose I have the following table:
| Name | Order | LinkStatus | LinkDate |
| Jorge Ymeniz | 5331-ab | Linked | 20200215 |
| Frank Wright | 8633-dw | Unlinked | |
| Sasha Stromburg | 8135-bs | On Hold | |
| Liddy Dormund | 4872-ek | Linked | 20200110 |
Now I need to return all Unlinked, On Hold, and only Linked if they exist between a couple of user input dates.
The SQL statement would look like:
select *
from myTable
where (LinkDate >= '20200201T000000.000 GST' or LinkDate is null)
or (LinkDate <= '20200227T235959.999 GST' or LinkDate is null)
This would return the following result:
select *
from myTable
| Sash Stromburg | 8135-bs | On Hold |
And I can't use LinkStatus, because that is also a filter that the user can choose.
The problem I'm running into is that when I leave the FromDate and ToDate blank (from the user selected filter page), I get the following:
select *
from myTable
where (LinkDate is null)
or (LinkDate is null)
Which then excludes any record that has a LinkDate. In this situation, I want all the records returned.
Essentially, I need to do is:
if FromDate != ""
then return "SourceDate >= FromDate OR SourceDate is null";
else return;
if ToDate != ""
then return "SourceDate <= ToDate OR SourceDate is null";
else return;
