SINARMASMSIGLIFE
ID
Last activity: 21 Mar 2017 4:53 EDT
Connect SQL using property statement
hi,
I have a problem with activity which calling RDB-Open using statement query by property when the contents of the property , i'm took from DB.
for example , value the propery is SELECT GREATEST(75, 5 * $P{AX} * $P{AZ} / 100 * $P{CC}) ABZA FROM DUAL , and then i'm passing into RDB - OPEN that property.
anyone can help me :)
thanks
Refer below two URL's for getting inputs on your use case.
