Transport for NSW
Last activity: 30 Jan 2021 12:49 EST
Tomcat is not starting after upgrading from pega 722 to 83
We're doing an upgrade from Pega 722 to Pega 83 and after upgrade we found that tomcat is not up.
This is what we have done as part of upgrade.
1) Migrated 722 rules and data schema to new rules and data schema
2) Ran Pega83 upgrade.sh script on the migrated schemas and it went fine.
3) For app server setup, created new instance of tomcat and copied *.war files to webapps directory after giving db details in conf/context.xml file
4) Ran startup.sh - found tomcat connects to DB, does build rules cache etc and at the end of Catalina.out log found these errors and there is nothing logged after these logs and tomcat kind of hangs after this and is never up.
2020-02-13 14:11:12,092 [il INITIALIZE_SEARCH] [ STANDARD] [ ] [ ] (Manager.PegaSearchProviderImpl) ERROR - Cannot enable full-text search for node 344FCBA818ACA3ACC34290D33196669D. Possible cause : None of the search index host nodes are reachable. 2020-02-13 14:11:42,238 [il INITIALIZE_SEARCH] [ STANDARD] [ ] [ ] (artup.SearchInitializationTask) ERROR - Finished configuration of node for full-text search, with errors
Has anyone faced this or any ideas to solve this?
