Unable to create Repository in Candidate System
We are setting up Deployment manager v4.6 and as per the guideline the repository should be created in both Orchestration and Candidate system. In Orchestration server we are able to create repository rule successfully, however while creating the same in candidate system, we get error "Could not connect to repository" as shown in the screenshot.
Network Ports are open between Candidate and Artifactory server, hence the only difference we can find here is Candidate system uses http://, however Orchestration and Artifcatory server both uses https://. Should it be a problem?
