Virtusa
Last activity: 29 Jan 2020 12:05 EST
Creating PDF document from a Template
How to create a PDF document from a template in Pega Infinity.
Hi Praneeth,
Please check the attached document, step by step process is mentioned to generate the PDF in the case.
Hi Pranneeth,
You can check the below link, it will be helpful for you to generate PDF using Eform.
https://community1.pega.com/system/files/Converting%20PDF%20to%20EForm.pdf
Hi Praneeth,
Below is the attached configuration which I tried in my local, and it works fine. You can follow the steps which are mentioned in these docs, which would be helpful.
Virtusa
Hi bhars1,
I am unable to get pdf document in the attachments section while I tried from the document you provided.
Hi Praneeth,
The attached document, describe how to generate PDF and attach to the case if your requirement is
to attachment section than you need to customize it according to your requirement.
Hi Praneeth,
Virtusa
This worked out.
Thanks siddharth.
Good to hear, the solution worked for you !!
