  EY
Last activity: 4 Mar 2016 14:17 EST
How to Create PDF from a Word Template Rule
We have one reauirements to generate PDF file from a word template rule without user interaction action using a back end activity.Please suggest how we can solve the problem.
SG
Hi, I've escalated this to the relevant SME team and hopefully you will get a reply shortly.
would referring to OOTB activity 'ConvertAttachmentToPDF' helps?
  Virtusa
Hi,I have one requirement
I have to produce some values to the pdf template from clipboard.
First I have to crate a pdf template in the required format .
How to create a pdf template in my the required format,and then how to upload it to pega.
Please explain me the process
Thank you
could you please check DesignerStudio --> Integration --> Tools --> PDF for EForm wizard if that helps...
  Pegasystems
See the help on Eforms and the EForm accelerator (wizard).
  Virtusa
Thank you...
  Pega
Hi Suresh,
You can use createPDF smart shape in the process flow, where you need to provide the section name.
  Capgemini
Any suggestions on how to convert a .doc file to .pdf . The .doc file is already present.
