Last activity: 21 Jan 2020 5:28 EST
Modal dialog does not start when adding a new record to an empty table.
When I add the first record to an empty table, the modal dialog doesn't open. However, if there is at least 1 record in the table, the modal dialog works correctly.
Also, adding the first entry works correctly if we specify: row editing-Inline.
The data hierarchy is shown in the screenshot. .ListCriteria used as a source.
Can you tell me what the problem could be? The use of modal dialog is requirement.
