Ruletek LLC
Last activity: 14 Oct 2019 11:33 EDT
Issues implementing the optimize table OOTB functionality.
I'm having issues implementing the optimize table OOTB functionality. When I select the "Optimize" and "Personalize Table" options, and then compare the table in the UI before it was selected, some dramatic changes occur. First of all, the "customize table" button, hides 2 of the 3 UI elements I had in the header of my table, secondly, it moves the paginator that I have set to be on the far left side of my table to the far right side of the layout, and hides half of it. Any suggestions?
Hi Jeremiah,
Can you please share the screenshot of the screen without personalization enabled? As I can see in your screenshots, the customize table button and Pagination is showing correctly as it should be.
Also, have a look at pyGridPersonalizeActions section as per your requirement.
