  Deloitte India
Last activity: 11 Nov 2019 10:22 EST
Not able to login Pega Platform 8.3.0 Login
After successful installation of "install.bat" file, an application opens. But unable to open it with the same credentials, could you please assist with the exact credentials we need to login.
  Virtusa
First time you have to login with
UserId : [email protected]
Pwd : install
After login you can create a new operator for you and you can use that.
FR
Can you check your logfiles to verify what the error could be exactly?
You should use the admin password you specified in the setupDatabase.properties file as the password for [email protected]. System will ask you to create a new password during login.
  Deloitte India
Thank you so much. Its working.
  Virtusa
Pwd : install
If its fresh installation of PRPC issue, Password would be provided in properties file or it would have been provided during installing of the PRPC.
If issue occurring after any upgrade, kindly try with cache clean once from DB and from App server to test the Login.
  TCS
I am getting "Access Error: 404 -- Not Found" on first time login into Pega 8 after installing. Someone please help. There were some posts telling to start DB2 server, how can I start and connect?
  PEG
Well yes the database server will need to be running. If you managed to run the install script, then this must have been up (at least at that time).
But this appears to be a different issue to the original posting, right?
Did you deploy the prweb.war or one of the equivalent .ear files to the application server?
HTTP Status 404 – Not Found
Type Status Report
prweb/PRServlet:
Description The origin server did not find a current representation for the target resource or is not willing to disclose that one exists.
Apache Tomcat:
Type Status Report
prweb/PRServlet:
Apache Tomcat:
Ideally Access Error :404 not found error occurred when the port is already used by other application/server.
So here it seems 8080 port is already used by another application 1/ you can try to find out which app is using it, using "netstat -aon" and stop the process; 2/ you can go to server.xml and change from port 8080 to another one (ex: 8081)
  Booz Allen Hamilton
Hi
I also get the same error. Any solution please.
  PEG
So if this is the same error then you should see the port already in use through netstat -a
Or connect to it with, say, putty on the "machine port"
If this is the case, are you unable to change the port in the tomcat settings (server.xml?)
  Booz Allen Hamilton
When I checked the Logs, I found the reason as Caused by: java.lang.RuntimeException: PRAppLoader was not properly initialized, unable to load class com.pega.pegarules.web.servlet.WebAppLifeCycleListner
Please can I know what has to be done.
Thank you
