TCS
Last activity: 12 Jan 2022 18:02 EST
When i am starting the Pega Platform 8.3.0 Startup, Some time working, But i am getting error StreamServer.Default JOINING_FAILED
2021-08-20 15:36:28,517 [BackgroundProcessing] [ STANDARD] [ ] [ ] (rvice.operation.StartOperation) INFO - Starting service [DataFlow.BackgroundProcessing]
2021-08-20 15:36:29,523 [BackgroundProcessing] [ STANDARD] [ ] [ ] (rvice.operation.StartOperation) INFO - Successfully started service [DataFlow.BackgroundProcessing]
2021-08-20 15:36:32,379 [ervice-registry-task] [ STANDARD] [ ] [ ] (.tasks.TopologyChangedDetector) INFO - Services topology has changed. Current topology:
This node ==> Aggregation.Default b312cd25cde0972a82c6d3e4818dc939 Proprietary information hidden NORMAL (new node)
This node ==> DataFlow.BackgroundProcessing b312cd25cde0972a82c6d3e4818dc939 Proprietary information hidden NORMAL (new node)
This node ==> DataFlow.Search b312cd25cde0972a82c6d3e4818dc939 Proprietary information hidden NORMAL (new node)
This node ==> StreamServer.Default b312cd25cde0972a82c6d3e4818dc939 Proprietary information hidden PENDING_JOINING (new node)
This node ==> pega b312cd25cde0972a82c6d3e4818dc939 Proprietary information hidden startingUp
2021-08-20 15:41:39,810 [StreamServer.Default] [ STANDARD] [ ] [ ] (rvice.operation.StartOperation) ERROR -
Cannot start service [StreamServer.Default]. Will retry in 180 seconds. Remaining attempts: 1
2021-08-20 15:48:35,729 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8]
( internal.async.AgentQueue) ERROR - Agent [PESetup] activity [PESetup-Work.SetPortNumber] queue number [0] disabled due to execution errors ErrorMsg:
unable to execute agent: PESetup #0: PESetup-Work.SetPortNumberUnable to open an instance using the given inputs: pxObjClass = "Data-Agent-Queue",
pyRuleSet = "PESetup", pyNodeName = "b312cd25cde0972a82c6d3e4818dc939"
2021-08-20 15:48:05,311 [ervice-registry-task] [ STANDARD] [ ] [ ] (.tasks.TopologyChangedDetector) INFO - Services topology has changed. Current topology:
This node ==> StreamServer.Default b312cd25cde0972a82c6d3e4818dc939 Proprietary information hidden JOINING_FAILED (was PENDING_JOINING)
This node ==> pega b312cd25cde0972a82c6d3e4818dc939 Proprietary information hidden running (was startingUp)
2021-08-20 15:48:35,729 [ PegaRULES-Batch-3] [ STANDARD] [ ] [ PegaRULES:8] ( internal.async.AgentQueue) ERROR - Agent
[PESetup] activity [PESetup-Work.SetPortNumber] queue number [0] disabled due to execution errors ErrorMsg: unable to execute agent: PESetup #0:
PESetup-Work.SetPortNumberUnable to open an instance using the given inputs: pxObjClass = "Data-Agent-Queue", pyRuleSet = "PESetup", pyNodeName = "b312cd25cde0972a82c6d3e4818dc939"
2021-08-20 15:52:53,351 [EDULER_THREAD_POOL_2] [ STANDARD] [] [] ( QueueProcessorDataFlowHandler) WARN - Stream service not available
2021-08-20 15:52:53,352 [EDULER_THREAD_POOL_2] [ STANDARD] [] [] ( QueueProcessorRegistrar) WARN - Either of Data flow service or Stream service is not initialized. Skipping registration of queue processors.
Some time working good, But i didn't know i am getting the given erro.
Appreciate your help :)
