Royal Bank of Canada
Last activity: 28 May 2020 2:44 EDT
Not able to change Queue processor Tracer settings in PEGA 8.3.0
Unable to change the tracer settings for Queue processor in PEGA 8.3.0. Before the session starts, tracer settings are not enabled. By default, only 5000 events are getting traced and only 'Queue processing' event is auto selected under the 'Event Types to Trace' in the tracer options. Even if I pause and change the required tracer settings, it gets refreshed for every session.
Any help here ..On how to select the events and increase the max trace events
Likes (4)
Sreevani Kintali Sam mk Andrew Try Naresh Vukkalker -
Updated: 3 Apr 2020 14:28 EDT
Hello!
We looked into SR-D43491 and here's the resolution:
"Expected behavior of the queue processor tracer. Asked user to use the main tracer."
Hope this helps.
Pallavi M | Moderator | Pega Collaboration Center
interesting, I do not have such issues locally. What browser are you using? I tried with Chrome.
JAGADISH CHANDRA GANNAMANENI Karthick Murugesan Krishna Mohan K Yaswanth Devabhakthini Purushothaman Kumaravelu and 2 More
Hi Kevin,
I have tried with both internet explorer and Google chrome.
Queue processor tracer setting are not enabled before the start of the session . Only when the tracing event is kick started, settings option is getting enabled. Not sure if I'm missing anything. Enclosed the screenshot.
Divya
I suggest you open an SR and provide PegaRULES log. Also, take a look at the clipboard. There should be a page D_pzTracerSettingsForRequestor. If there is an error message there, add those details to SR.
Karan Narvani
Thanks Paul. I have checked D_pzTracerSettingsForRequestor page, there were no error messages in that. I will raise an SR.
Stella Caroline
I wonder if this is due to privilege of your particular user login. Have you tried with OOTB [email protected]?
Atanu Sen Midhun Krishnankutty Bueprint App Design Developer Events Manigandan Kannappan Elaine Garcia
UnitedHealthcare India PVT Ltd
Hi Divya,
Were you able to find the fix for this issue? I'm facing the same issue with job schedulers. The tracer window start with the execution of the job scheduler and after that the clicking on the setting icon doesn't open any window. So, basically there is no time to update the tracer setttings before job scheduler kicks in.
CGI
Kindly let us know if there is any hotfix for the above issue... Facing the same issue
Sopra Steria
Did you get any response so far? We are facing the same issue and it is pretty annoying.
Hello!
Hope this helps.
BearingPoint GmbH
DE
Hello, we have the same problem with Job Schedulers. The proposed solution to use main tracer is incorrect - it is impossible to use the main tracer to trace Job Schedulers or Queue Processors. Please provide a correct solution. Thanks.
JIAO HE Patrick Richardson Lokesh Lakshkar Abhiram Mv Peter Gousios and 5 More
