ASB Bank
NZ
Last activity: 1 Oct 2019 4:37 EDT
Calendar Gadget header
Hi Guys,
I have used the calendar gadget in my application.
The header of the calendar gadget was not properly displayed.
The bottom part is getting truncated a bit.
This truncation is abit more when I tried in other languages(Arabic, French etc.)
How to increase the header size??
Optum
Please use browser developer tool to find the ID of the calendar header and increase its height attribute to the desired px or % value to accommodate all language packs.
ASB Bank
NZ
I tried changing the header after using inspect tools, the header height seems to change a bit, but is not accommodating the whole letter
Optum
Could you please share screenshot of the issue you see after changing height attribute: "not accommodating the whole letter"?
Can you also share your current configuration? Also, please check below screen shot and see changing this is helping you. Thanks!
Updated: 27 Sep 2019 12:18 EDT
ASB Bank
NZ
I was asking about the Calendar Gadget, not Calendar control
My bad! However my idea is still the same, can you try changing the width options to see if it helps! I would suggest, try the suggestions in Pega OOTB application on Case Manager portal. If the issue reproduces there, you may open up an SR and we can help you further.
Can you confirm if you are using everything OOTB here? I mean did you try with OOTB harness/portal and check if the issue replicates? Also, using OOTB pyEnduser/pyEnduser7 skin
ASB Bank
NZ
I am using custom Harness(which has been overridden from OOTB harness)..no changes have done to the styling/width.
