Atos Syntel
Last activity: 4 Sep 2019 15:32 EDT
Difference between Back to back processing and Supporting process settings
There is a setting to look for assignments in both Flow and Flow Action rule
Flow Action rule:
Flow rule:
I am able to understand the setting in Flow action rule(can test it too), the setting in the Flow rule confuses me, I am not able to understand it and find a scenario to test it, please help.
This isn't something I've used myself, but the documentation suggests that "Supporting Process Settings" option looks for assignments after a Supporting Process has been launched (which might not be part of the same flow path the work object is currently on).
Here's are some help articles that describe the settings:
https://community.pega.com/sites/default/files/help_v71/rule-/rule-obj-/rule-obj-flow/processtab.htm
https://community.pega.com/sites/default/files/help_v83/procomhelpmain.htm#rule-/rule-obj-/rule-obj-flowaction/action.htm
Hope this helps!
-Kurt
