Ucare
Last activity: 2 Nov 2018 5:16 EDT
Difference between 2 DSS setting
Hello, I am trying to do DSS setting for the pega017 alert.I searched in pega community and learnt that i need to set up a dss setting. But i see 2 kind of setting .Not sure both are same or different.
Can someone help me understand the difference ?
Pega-Engine • prconfig/declaratives/fragments/instancecountlimit/default (set to 5000)
Pega-Engine • prconfig/declaratives/fragments/instancecountlimit (set to 5000)
I am not sure that the second DSS will work. The first one looks correct to me. When you use a DSS for a prconfig setting (with a prefix of "prconfig") the last part of the key should be the node classification that the setting applies to. This is normally "default" for prconfig settings.
See the followng help articles:
Creating a Dynamic System Setting
Changing a prconfig setting value for a subset of nodes
