    Blue rose Technolgoies
MY
Last activity: 29 Aug 2019 7:25 EDT
Component stack mismatch in Pega 8.1.3
Hi Team
I am getting Component stack mismatch error in Pega 8.1.2 in Prod while analysing AES Logs .Can i know the reason and any fix if applies?
Below is the Java Stack
at com.pega.pegarules.session.internal.mgmt.autostreams.uicomponent.json.UIComponentRuntimeImpl.finishProcess(UIComponentRuntimeImpl.java:175) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.autostreams.uicomponent.json.AbstractUIComponent.endComponent(AbstractUIComponent.java:89) ~[prprivate.jar:?]
at com.pegarules.generated.html_section.ra_stream_pycasemain_b16319206a9e37e2189d38c61f27e996.pzLayoutContainer_3(ra_stream_pycasemain_b16319206a9e37e2189d38c61f27e996.java:452) ~[?:?]
Hi Team
at com.pegarules.generated.html_section.ra_stream_pycasemain_b16319206a9e37e2189d38c61f27e996.pzLayout_3(ra_stream_pycasemain_b16319206a9e37e2189d38c61f27e996.java:476) ~[?:?]
at com.pegarules.generated.html_section.ra_stream_pycasemain_b16319206a9e37e2189d38c61f27e996.pzSectionBody_1(ra_stream_pycasemain_b16319206a9e37e2189d38c61f27e996.java:268) ~[?:?]
at com.pegarules.generated.html_section.ra_stream_pycasemain_b16319206a9e37e2189d38c61f27e996.performStream_1(ra_stream_pycasemain_b16319206a9e37e2189d38c61f27e996.java:682) ~[?:?]
at com.pegarules.generated.html_section.ra_stream_pycasemain_b16319206a9e37e2189d38c61f27e996.execute(ra_stream_pycasemain_b16319206a9e37e2189d38c61f27e996.java:144) ~[?:?]
Note:I see a Patch in Pega 8.1.3 but it is related to some other issue with same exception.
