Allianz SE
Last activity: 15 May 2020 14:32 EDT
Pega 8.1.3 installation issue
While trying to install Pega8.1.3, installation is always stopping at the below step. I tried installing many times by clearing the schema but installer is stopping at the same step. Anyone faced the same issue ?
Engine Load Inner:
[java] 2019-10-03 21:55:30,089 (com.pega.pegarules.internal.bootstr) 1050 - Loading bootstrap properties from file:///C:\Users\AD_MOH~1\AppData\Local\Temp\239\/PegaInstallTemp-03-October-2019-21.49.39/prbootstrap.properties
[java] 2019-10-03 21:55:30,119 (com.pega.pegarules.internal.bootstr) INFO - Could not find java:comp/env/prbootstrap/ in the local JNDI context, skipping prconfig setting lookup
[java] 2019-10-03 21:55:30,123 (com.pega.pegarules.internal.bootstr) INFO - Could not find prbootstrap in the local JNDI context, skipping prconfig setting lookup
[java] 2019-10-03 21:55:30,125 (com.pega.pegarules.internal.bootstr) 1050 - Unable to locate archive.properties properties, setting warVersion to -1
[java] 2019-10-03 21:55:30,126 (com.pega.pegarules.internal.bootstr) 1050 - Engine schema defined in allclasses: null
[java] 2019-10-03 21:55:30,127 (com.pega.pegarules.internal.bootstr) INFO - Could not find java:comp/env/prconfig/ in the local JNDI context, skipping prconfig setting lookup
[java] 2019-10-03 21:55:30,128 (com.pega.pegarules.internal.bootstr) INFO - Could not find prconfig in the local JNDI context, skipping prconfig setting lookup
[java] 2019-10-03 21:55:30,128 (com.pega.pegarules.internal.bootstr) 1050 - Engine classes schema: null
[java] 2019-10-03 21:55:30,129 (com.pega.pegarules.internal.bootstr) 1050 - Assembled classes schema: null
