Routing surveys to multiple users at the same time?
I have a requirement that a survey needs to be routed to 7 users at the same time. Is this possible ? How should I configure my flow ?
Update: Tried Split Join but I get this error while saving the rule: "Connectors from the split join container to the embedded process must be of type always or when"
Thank you.
