Problem with operator instance saving
I am changing the email address of an operator in production level but the email address goes back to it's old value some time later. This situation repeat many times. I changed the email address of the operator like 8-10 times but still when I open the operator's profile some time later, I see the old email address. This is so awkward. What could cause this situation ?
Thank you.
Point 1: If you by mistake used any activity to update an operator (Obj-Open > Property-Set > Obj-Save), it won't leave an audit trail. So, just make sure that none of your functionality is updating the application profile by mistake (SSO?)
Point 2: If you believe that profile is corrupted, try to revalidate and save it once.
Point 3: If issue persists, check the log for any exception/error as soon as you update the profile and save it.
