Contra Costa County
Last activity: 6 Aug 2019 11:29 EDT
Pega to SQL Server Database Connection
Hello Team,
We're having an issue with installing Pega 8.2 on Database Connection screen. We supplied the database parameters and jdbc driver, but when we clicked the Test Connection button it doesn't do anything neither error message displayed.
Attached is a screen shot.
Thank you for help.
Decision Consultant Solutions
As you are doing set up from windows OS, You can do the installation using the 'install.bat' file.
Modify the file as per the installation guide and run it from command prompt. See if you are getting any error.
Run the 'install.bat' from the media file only. Don't try running it by copy and paste it in a separate folder.
that is odd, can you first put the jdbc jar somewhere else without blank string in the path? (e.g., Program Files).
Contra Costa County
Hi Kevin,
I tried to put the jdbc jar on different location without a space on the path and still the same, not doing anything.
Thanks.
Is there any error in the launch window? An alternative is to run install.sh directly under the script directory.
Contra Costa County
Thank you, I was able to install successfully using the install.bat file.
Can you write a simple jdbc code in IDE and verify if db connection is successful or not.
Is symantec end point protection is enabled in your system?
Abhinav
Provide PRPC_Setup-date.log located in scripts\logs directory
Regards
Simon
