Localized value not showing in Grid filter
I'm having a similar problem as described in SA-14830, SA-37957 and SA54531.
I'm working in Pega 8.1 and have a table with localized values in the columns (as Text Input fields) and the filter is enabled.
When I open the list of the filter I can see a non-localized value in the list that is localized in any other part of the application, including the column value in the table.
I tried to implement a given solution that says you should change the field type in the column to "Control inherited from property", but this solution actually makes the field in the column to show up non-localized and is therefore not usable.
Does anyone have a solution to my problem?
Thanks in advance.
