AI4Process
Last activity: 19 Aug 2017 3:01 EDT
Filter issue on Repeating Grid, Showing double values on the filter.
We have a repeating grid layout loads on ReportDefintion. We have applied filter options for this grid.
The problem is on click of the filter icon we see two values in the criteria for each row!
Lets say i have a column with value "First". On filter i see the string "FirstFirst".
Is there any setting to remove this?
Veera
Infosys
remove it from dyanmic layout and keep only grid layout..
I have the same issue on PRPC 7.2.1, in the filter list even 4 entries appear per record. To put the grid for itself is not an option because the appropriate section is re-used per section-includes in other places. Any other solution, maybe a fix is already available?
Something to add:
The amount of entries per record are also differs, for some onely 1 entry is visible, for others 2 or 3 or even 4 entries. This is weird....
If there's any solution which requires a specific configuration, please can you describe in details? Many thanks in advance.
Techmahindra
Hello Mike,
For 7.2.1 also we have this hotfix being ported. You can raise an existing hotfix request for HFix-29322. However this is planned to be fixed in PRPC 7.2.2.
Shanthini Charles
Hi Mike,
If you end up raising an SR for the hotfix, please reply here with the SR number so we can link this post to the SR.
Thanks!
Marissa | Community Moderator | Pegasystems Inc.
New Jersey Judiciary Administrative Offices of the Courts Information Technology Offices
I am having the same issue, running PEGA 7.1.7.
Hi SerafimS,
This issue can be because of the usage of two or more grids bind to same source inside dynamic layout.
Root cause for this issue is "partial trigger params generated for grids with same source is not unique when the grid is placed inside dynamic layout"
A Local change suggested above for this works and it is "moving grid out of dynamic layout and keep only grid layout".
( or )
There is also hotfix HFix-27567 for this in Pega 7.1.7 that can be tried.
Blue Rose Technologies GmbH
DE
Aegon
Hi
I had the same issue as I was displaying 2 grid repeats that referred to the same page list in the same dynamic layout.
I saved the grid repeats into separate sections and referenced both sections in the original dynamic layout. This resolved the issue.
Iain
capgemini
Faced this issue and moved grid out of dynamic layout. It worked fine !! Thanks
