NTT DATA Global Delivery Services Pvt Ltd
Last activity: 10 Jul 2019 5:38 EDT
Error while using pyMobileSnapStart to open a work item
We are trying to implement a solution for opening a workitem from an email. On click of this link we have to open the portal and the work item in the context should be loaded.
To achieve this:
1. We have tried using 'pyMobileSnapStart' as per the instructions provided in https://community1.pega.com/sites/pdn.pega.com/files/help_v73/procomhelpmain.htm#mobile/concepts/mob-use-snapstart-module-outside-sdk-con.htm.
However, when we did this, we get to see the following error :
To achieve this:
2. I have also tried using worklink correspondence provided OOTB to open the work item using the inskey. But this is working only for the developer portal URL and for the customer portal URL it throws the following error:
So, can some one help me identify the issues here. I have attached the stack trace for scenario 1.
Appreciate your help!
