Pega BIX extract to shared path
I have created an extract rule and am trying to extract data to an external database.
While running the rule - we get option to generate the schema to be run for the first time. i want to give a shared path here , as we do not have access to the pega backend server
The perform extract runs - but no schema script is created in the path. Please let me know what needs to be done for the schema file to be created on shared network path. is there any permmisions to be set. All ports are open
Hi
As per screen shot, schema has been created but file name contains two file extension i.e. .txt and .sql ideally it should be .sql only , please follow below instruction and try once.
