How to set BIX Extract path directory dynamically .
Is there anyway to set BIX extract path dynamically .
Brahmesh - I have the same concern with BIX. Tried passing the path as Param and also tried referencing a Data Page, neither one worked.
At this point, I don't think there is way to do that.
We are on Pega 7.4 and running BIX 7.4.
If you are running from command line, the -P parameter can be used to to override the specified output directory. This is not available when running an Extract rule with pxExtractDataWithArgs.
