Independent
Last activity: 25 Feb 2020 9:26 EST
Rule Search Index Not Being Updated / pyFTSIncrementalIndexer Exception Pega 8.1.3
The Rule Search Index is not being updated.
Upon checking the PegaRULES log file, the pyFTSIncrementalIndexer is throwing out exception.
The following is the first couple lines from the PegaRULE log file:
2019-05-22 14:57:14,048 [CHEDULER_THREAD_POOL] [ STANDARD] [ ] [ ] (ueueProcessorFailedRunsManager) ERROR - Unable to re-start failed queue processor pyFTSIncrementalIndexer. Caught exception: Cannot resubmit the run [pyFTSIncrementalIndexer] because some of its partitions are not in end state
java.lang.IllegalStateException: Cannot resubmit the run [pyFTSIncrementalIndexer] because some of its partitions are not in end state
PRPC Version: 8.1.3
***Edited by Moderator: Lochan to update SR details***
Likes (1)
shilpa kunuku -
As per tSR-D17907 notes,The root cause of this issue is When a Queue Processor's Kafka partition ends up in an unknown state, the automatic restart does not clear the partition which results in the exception, and the queue processor fails to be restarted.
It got resolved by using the API function pxStartRunByID, and pass it the failed queue processor's name. This API function will reset the state of the partition when it starts the run.
You can verify the Queue Processor is running normally from the Admin Studio > Resources > Queue Processor page.
In 8.1.6, this is addressed by having the automatic restart functionality also reset the state of the kafka partition when a failed run is restarted.
Abhinav
Can you please see what is the status of Stream node ( Pega Landing page --> Decisioning --> Infrastructure )?
Independent
Statuses of both the agent and the stream node appear to be fine. Please see the two attached images.
Seri Charoensri Thomas Zink
SR-D17907 was created to investigate this issue.
Will update this thread further when the issue is resolved.
Vodafone
ES
Aparently we have the same scenario: same error, same PRPC version... So we apreciate any information added to this post to try to solve it.
Raquel
Call the API function: Data-Decision-DDF-RunOptions pxStartRunByID
This API function resets the state of the partitions of a (failed, in this case) queue processor and starts the run. You will pass it the ID of the queue processor that is stuck in a failure state - in this case, pyFTSIncrementalIndexer.
Starting in 8.1.6 and 8.2.3, this resetting the state of the partitions will be used when the engine performs automatic restarting of failed queue processors so that this scenario where the partition is in an unexpected state is handled by the automatic restart.
You can check that the queue processor is running properly after doing this by going to Admin Studio > Resources > Queue Processors
THARUN K T
Charles Schwab
Hi Syl, I am unable to find an option to call this API function "Data-Decision-DDF-RunOptions pxStartRunByID". Can you provide a set of steps for the same ?
Hi - what version are you using? The above recommendation relates to 8.1.x prior to 8.1.6, and 8.2.x prior to 8.2.3. Perhaps make a new thread. 7.x indexing uses different mechanisms entirely so your error would not be identical, nor would the API functions be available.
Also, if you're attempting to find this rule in your environment using the search bar, you need to check the enable diagnostic checkbox in your operator profile (click your initials/profile picture in the lower left of dev studio > preferences)
Centene
We have upgraded from 8.1.3 to 8.1.6 and still have this issue. Do we need to reset ?
Abhinav
Pratik Agarwal
Centene
It is addressed in 8.1.6,If it did not work then please perform the same steps that you have done in previous version.
Abhinav
Delete the instance(pyFTSIncrementalIndexer) of Data-Decision-DDF-RunOptions-Queueprocessor will also restart the data flow if the resume button is disables but it needs a restart.
Independent
Is the fix put in for Pega 8.1.6 also put into Pega 8.3?
