ECLANTIQX
Last activity: 27 Mar 2019 18:34 EDT
"Unable to start process notepad.exe. Start process injected C:\Windows\System32\notepad.exe failed"
Hello All,
I'm receiving the below error when tried to launch any kind of windows application, pl let me know how can i overcome this and proceed to launch for windows application. Please find the error below.
Hello All,
Info | 09:54:27.864 PM | 19 | MTA | Windows Adapter | Windows Application1 | | Starting adapter
Verbose | 09:54:27.864 PM | 19 | MTA | UI Connectors | | | ExpressTranslatorService.EnsureTranslatorsLoaded() - ENTER
Info | 09:54:27.864 PM | 19 | MTA | Adapter Reparenting | Windows Application1 | | WindowsAdapterBase.StartProcess: No user control has registered to reparent this adapter
Info | 09:54:27.864 PM | 19 | MTA | Windows Adapter | Windows Application1 | | Starting Process - Target: , Path: C:\Windows\System32\notepad.exe, Dir: C:\Windows\System32, Args: , Timeout: 10000
Info | 09:54:27.868 PM | 34 | STA | Windows Adapter | | | InvocationForm.OnHandleCreated: Found internal SetState2
Info | 09:54:27.869 PM | 34 | STA | Windows Adapter | | | InvocationForm.OnHandleCreated: Calling base...
Info | 09:54:27.870 PM | 34 | STA | Windows Adapter | | | InvocationForm.OnHandleCreated: Base called
Info | 09:54:27.883 PM | 34 | STA | | | | WindowsProcess.WndProc( 133340, 18, 1, 0 )
Info | 09:54:27.884 PM | 34 | STA | | | | WindowsProcess.WndProc( 133340, E, 0, 0 )
Info | 09:54:27.885 PM | 34 | STA | | | | WindowsProcess.WndProc( 133340, D, 1, 504033100 )
Info | 09:54:27.886 PM | 34 | STA | | | | WindowsProcess.WndProc( 133340, 46, 0, 504034252 )
Info | 09:54:27.887 PM | 34 | STA | | | | WindowsProcess.WndProc( 133340, 47, 0, 504034252 )
Info | 09:54:27.888 PM | 34 | STA | | | | WindowsProcess.WndProc( 133340, 5, 0, 148 )
Info | 09:54:27.888 PM | 34 | STA | | | | WindowsProcess.WndProc( 133340, 3, 0, 4587561 )
Info | 09:54:27.889 PM | 34 | STA | | | | WindowsProcess.WndProc( 133340, C208, 0, 0 )
Error | 09:54:28.853 PM | 19 | MTA | Exception | | | Unable to start process notepad.exe. Start process injected C:\Windows\System32\notepad.exe failed, Verbose Message: General Information
Diagnostic Info:
Diagnostic.MachineName: LAPTOP-B183I5TG
Diagnostic.FullName: OpenSpan, Version= Proprietary information hidden, Culture=neutral, PublicKeyToken=f5db91edc02d8c5e
Diagnostic.AppDomainName: DefaultDomain
Diagnostic.WindowsIdentity: LAPTOP-B183I5TG\Sree Harish
Diagnostic.ApplicationName: OpenSpan.Studio.Shell
Exception Information
1) Exception Information
Exception Type: Pega.Exceptions.BaseApplicationException
MachineName: "LAPTOP-B183I5TG"
CreatedDateTime: 20-03-2019 21:54:28
AppDomainName: "DefaultDomain"
ThreadIdentityName: "LAPTOP-B183I5TG\Sree Harish"
WindowsIdentityName: "LAPTOP-B183I5TG\Sree Harish"
AdditionalInformation: NameValueCollection with 0 items
Message: "Unable to start process notepad.exe. Start process injected C:\Windows\System32\notepad.exe failed"
Data: IDictionary (System.Collections.ListDictionaryInternal) with 0 items
TargetSite: Boolean Start(OpenSpan.Adapters.Windows.WindowsProcessStartMethod, System.String, System.String, System.String, System.String, Int32)
HelpLink: NULL
Source: "OpenSpan.Adapters.Windows"
HResult: -2146232832
StackTrace Information
at OpenSpan.Adapters.Windows.WindowsProcess.Start(WindowsProcessStartMethod method, String path, String args, String dir, String target, Int32 timeout)
at OpenSpan.Adapters.Windows.WindowsAdapterBase.StartProcess(WindowsProcessStartMethod method, String path, String args, String dir, String target, Int32 timeout, Boolean hookChildProcesses, IWindowsProcess& process)
at OpenSpan.Adapters.Windows.WindowsAdapterBase.StartProcess(WindowsProcessStartMethod method, String path, String args, String dir, String target, Int32 timeout, IWindowsProcess& process)
at OpenSpan.Adapters.Windows.WindowsAdapter.StartAdapter()
at OpenSpan.Adapters.Adapter.HandlePerformStart(Object sender, CancelEventArgs e)
at OpenSpan.Design.DesignComponentCommon.OnPerformStart()
at OpenSpan.Design.DesignComponentCommon.Start()
at OpenSpan.Design.DesignComponent.Start()
at OpenSpan.Adapters.Design.InterrogationService.StartInterrogation()
2) Exception Information
Message: "Start process injected C:\Windows\System32\notepad.exe failed"
TargetSite: Void InjectAndResumeProcess(System.String, System.String, System.String, UInt32 ByRef)
HelpLink: NULL
at OpenSpan.Adapters.Windows.WindowsProcess.InjectAndResumeProcess(String path, String args, String dir, UInt32& pid)
Info | 09:54:31.512 PM | 34 | STA | | | | WindowsProcess.WndProc( 133340, 86, 0, 0 )
Info | 09:54:31.515 PM | 34 | STA | | | | WindowsProcess.WndProc( 133340, 6, 0, 0 )
Info | 09:54:31.517 PM | 34 | STA | | | | WindowsProcess.WndProc( 133340, 8, 0, 0 )
Info | 09:54:31.521 PM | 34 | STA | | | | WindowsProcess.WndProc( 133340, 281, 0, -1073741809 )
Info | 09:54:31.525 PM | 34 | STA | | | | WindowsProcess.WndProc( 133340, 282, 1, 0 )
